Online Now [294]:
Visitors: 294
Today: 106240
Total: 142374283
Forums › The Car › 206 Problems › Excessive fuel usage
kerry
PostPosted: Fri Jan 28, 2011 6:31 am Up
Hello I have a peugeot 206 1.4 8v petrol 53 plate it had to have a new centre and box box exhaust last October since then it is using fuel badly i have an app on ipod to keep record of mpg etc and it is coming out as 25 mpg but use to be up in the 35-40 ish . This week it has cost me £15.00 to do 64 miles !!!!
Have had car plugged into Snap-on computer reader and it is showing no faults codes at all.
It is idling erratically when cold but it fine when it warms up. car has full service history when i bought it 10 months ago i have had new spark plugs fitted and oil and filter change in August car drives like a dream, it has done 87,000 miles.
I would be so grateful for any advice on what could be the matter with it as not got loads of money to throw at it, but need to put it right if i can find out what is it.
.Thankyou Kerry
Peugeot 206 1.4 petrol 53 reg
jamiea69
PostPosted: Fri Jan 28, 2011 6:52 am Up
it idles higher when its cold to warm engine up quicker, not reali sure y your using more fuel, what sort of driving you do?
225 cupra r
kerry
PostPosted: Fri Jan 28, 2011 7:16 am Up
I do quite a lot of short journeys but taking it on a run ie 50 miles makes no difference to the amount of fuel it uses, ipod still saying 25 mpg and before anyone asks i'm not heavy footed !! lol
It dles bewteem 800 and 1200 when cold.
bashyy1
PostPosted: Fri Jan 28, 2011 7:18 am Up
same situation with me....£10.00 puts my fuel gauge up 1 line...thats an 1/8 of a full tank
Aegean Blue Gti 180.
Project Thread
Kersh
PostPosted: Fri Jan 28, 2011 10:05 am Up
try running some redex cleaner through your system, might shift some of the crap
Member number: 36
spike_202
PostPosted: Fri Jan 28, 2011 10:16 am Up
ipod? How does that tell you what mpg you are doing its not connected to the ecu is it?
**spike's project**
TEAM:+200bhp
kerry
PostPosted: Fri Jan 28, 2011 1:40 pm Up
Its had a wurth fuel cleaner in september made no difference to it.
Ipod has an app that you put in the milage, fill the car up then keep it full and every time to go to the garage you put milage, how many litres cost per litre and it keeps a graph and chart of mpg for you and works out how much a mile the car cost to run. Its called "gas log".
PostPosted: Fri Jan 28, 2011 1:41 pm Up
Use shell by any chance? Wink
kerry
PostPosted: Fri Jan 28, 2011 3:02 pm Up
Yes Shell's normal unleaded !
dturbopeck
PostPosted: Fri Jan 28, 2011 3:12 pm Up
WELCOME
PostPosted: Fri Jan 28, 2011 3:19 pm Up
Fuel saver by any chance? That be the reason, i found it to be of extremly bad quality causing the car to use more than less Laughing
Mine is a 1.4 btw
kerry
PostPosted: Fri Jan 28, 2011 3:29 pm Up
no fuel saver on it !
PostPosted: Fri Jan 28, 2011 3:36 pm Up
I thought they got rid of standard shell fuel for only fuel saver? Confused
kerry
PostPosted: Fri Jan 28, 2011 7:01 pm Up
I just use the standard shell fuel !!
no_offences
PostPosted: Fri Jan 28, 2011 8:34 pm Up
who honestly gives a flying f***???? if your so botherd about mpg go a by 800cc daewoo matiz
Signature removed due to size
