Latest: S2cgm
Overall: 17178
Online Now [117]:
Visitors: 115
Bots: 2
Today: 20735
Total: 136665977
Forums › The Car › 206 Problems › Help plz
Help plz
zezotornado
PostPosted: Fri Jan 28, 2011 12:26 pm Up
I clean my car today and the worker clean the mfd screen with water and these are a couple of pics
any ideas ?????? Question
PostPosted: Fri Jan 28, 2011 12:31 pm Up
Water has got in the screen by the looks of it. Could try removing it and sticking it near some heat like a radiator or out in the boiling hot sun in your case Laughing
Lee180
PostPosted: Fri Jan 28, 2011 12:32 pm Up
Go get your money back Wink but yeah, try using the radiator to remove the damp
Originate, don't duplicate.
zezotornado
PostPosted: Fri Jan 28, 2011 12:35 pm Up
thx for that
but i don't know how to remove it ?
i need help in this .
PostPosted: Fri Jan 28, 2011 12:37 pm Up
lift the top plastic cover off and youll see 2 torx screws on the unit
zezotornado
PostPosted: Fri Jan 28, 2011 12:42 pm Up
i try to lift the plastic cover but i am afriad it will broken .
in what direction i must remove it ?
PostPosted: Fri Jan 28, 2011 12:43 pm Up
start from the back at lift up then the front will slide.
zezotornado
PostPosted: Fri Jan 28, 2011 12:45 pm Up
thnx mate i will give it a try and post here again
zezotornado
PostPosted: Fri Jan 28, 2011 1:02 pm Up
immediately after the clean nothing appear in the screen but i wait about 20 min. then the screen work except the 1st line as you can see in the pics .
is that water ? or the screen damaged ?
apjs87
PostPosted: Fri Jan 28, 2011 1:08 pm Up
find him, punch him and then dry it out properly over night on a rad or sumthing
No longer a 206 owner
Astra H sxi. 1.7Cdti
Rob2859
PostPosted: Fri Jan 28, 2011 1:20 pm Up
or you could just make him buy you a new unit? don't want it fixing for the problem to come back later on when you can do nothing about it
zezotornado
PostPosted: Sat Jan 29, 2011 3:28 pm Up
hi,
i went to the local Peugoet dealer and they said it can't be fixed so i have to buy a new unit .
thnx for the help I really appreciate that .
PostPosted: Sat Jan 29, 2011 3:44 pm Up
Did you even try drying it?
zezotornado
PostPosted: Sat Jan 29, 2011 3:47 pm Up
yes i leave it in the sun (you know the sun in the meadle east ) and still the upper part not work .
