Latest: tbafonso
Overall: 17130
Online Now [93]:
Visitors: 92
Today: 2565
Total: 104152612
Forums › The Car › 206 Problems › timming belt
timming belt
sp5flys
PostPosted: Sat Jan 29, 2011 3:34 am Up
i have a 206 2.0 hdi and has started sweaking
when i start the car its fine for the 1st 10mins after that it starts sweaking im pretty sure its timming belt/drive belt,
does anyone know what i can do to stop this noise?
Thank you
.. Peugeot 206 2.0 D turbo hdi ..
eddrj
PostPosted: Sat Jan 29, 2011 3:36 am Up
probably be the fanbelt {auxbelt} not the cambelt.
i had this a few times probably just needs fanbelt tighten up a bit , easy cheap job
if not mabey needs new fanbelt only £20 and any garage will fit one for cheap.
Old car 2000/ 206 2.0 hdi.
sp5flys
PostPosted: Sat Jan 29, 2011 4:12 am Up
cheers i get that done
kieron
PostPosted: Sat Jan 29, 2011 4:25 am Up
the drive(aux) belt is on a self tention so its just worn out or maybe split or torn
Account suspended
PostPosted: Sat Jan 29, 2011 4:35 am Up
I've never heard of a timming belt sweaking.
sp5flys
PostPosted: Sat Jan 29, 2011 5:41 am Up
E5gdm i ment drive belt,
How long do drive belts last im sure it was changed a few years ago by the last owner? would wd40 help?
Thank you
eddrj
PostPosted: Sat Jan 29, 2011 5:48 am Up
probably would be every few years meant to check them every half year ,really says in haynes manal.
sounds about right ive had a few fanbelts before because they have squeaked and squealed.
copey
PostPosted: Sat Jan 29, 2011 5:54 am Up
Thank you
well as its spinnign its charging the alternator, so if you put wd40, i would assume it would then slip granted stopping the noise but not charging the battery properly
02 2.0 hdi d turbo
PostPosted: Sat Jan 29, 2011 11:47 am Up
Never heard of a drive belt sweaking either I'm afraid.
sp5flys
PostPosted: Sat Jan 29, 2011 11:54 am Up
:/ u ever heard of any belt squeaking because im pretty sure it is, and the other replys ive had looks like there heard of it too?
00budham00
PostPosted: Sat Jan 29, 2011 11:59 am Up
yeah lol same here mine sounds like a bird chirping !! gets loud @80
|øgæn
PostPosted: Tue Jul 12, 2011 11:04 am Up
Have you checked your "tensor polley" ? (or pulley, not sure how to writte it in english) just change my accesory belt, because the last one was quite worn, but the squeaking noises continued in the morning start ups, specially with this rainy days, just checked the polley and found that the tensor one is about to die, you may need to check it too.
The WD40 on the drive belt is not so good, it´ll only do worst with the sound, you have to replace it, otherwise you can use "armor all" or "polish" (spray) but it won´t last.
Best Regards
Life is what happens while you have another plans
PostPosted: Tue Jul 12, 2011 11:05 am Up
it will when it is over tighten
PostPosted: Tue Jul 12, 2011 11:55 am Up
Blimey, I forgot about this thread, anyway now I know that the 'timming' belt will start 'sweaking' when it is 'over tighten'.
Thanks fellas.
JE_180
PostPosted: Tue Jul 12, 2011 11:57 am Up
Rolling On The Floor Laughing
