Posted: Sat Jan 29, 2011 3:34 am |
i have a 206 2.0 hdi and has started sweaking
when i start the car its fine for the 1st 10mins after that it starts sweaking im pretty sure its timming belt/drive belt,
does anyone know what i can do to stop this noise?
Thank you
| .. Peugeot 206 2.0 D turbo hdi .. | |
Posted: Sat Jan 29, 2011 3:36 am |
probably be the fanbelt {auxbelt} not the cambelt.
i had this a few times probably just needs fanbelt tighten up a bit , easy cheap job
if not mabey needs new fanbelt only £20 and any garage will fit one for cheap.
| New car 2011 / Thoruim grey , 207 1.4 Vti 16v Sport 95bhp , tinted rear windows.
Old car 2000/ 206 2.0 hdi. | |
Posted: Sat Jan 29, 2011 4:12 am |
cheers i get that done
Posted: Sat Jan 29, 2011 4:25 am |
the drive(aux) belt is on a self tention so its just worn out or maybe split or torn
Posted: Sat Jan 29, 2011 4:35 am |
I've never heard of a timming belt sweaking.
Posted: Sat Jan 29, 2011 5:41 am |
E5gdm i ment drive belt,
How long do drive belts last im sure it was changed a few years ago by the last owner? would wd40 help?
Thank you
Posted: Sat Jan 29, 2011 5:48 am |
probably would be every few years meant to check them every half year ,really says in haynes manal.
sounds about right ive had a few fanbelts before because they have squeaked and squealed.
Posted: Sat Jan 29, 2011 5:54 am |
sp5flys wrote: |
Thank you |
well as its spinnign its charging the alternator, so if you put wd40, i would assume it would then slip granted stopping the noise but not charging the battery properly
Posted: Sat Jan 29, 2011 11:47 am |
sp5flys wrote: |
E5gdm i ment drive belt, |
Never heard of a drive belt sweaking either I'm afraid.
Posted: Sat Jan 29, 2011 11:54 am |
:/ u ever heard of any belt squeaking because im pretty sure it is, and the other replys ive had looks like there heard of it too?
Posted: Sat Jan 29, 2011 11:59 am |
yeah lol same here mine sounds like a bird chirping !! gets loud @80
Posted: Tue Jul 12, 2011 11:04 am |
Have you checked your "tensor polley" ? (or pulley, not sure how to writte it in english) just change my accesory belt, because the last one was quite worn, but the squeaking noises continued in the morning start ups, specially with this rainy days, just checked the polley and found that the tensor one is about to die, you may need to check it too.
The WD40 on the drive belt is not so good, it´ll only do worst with the sound, you have to replace it, otherwise you can use "armor all" or "polish" (spray) but it won´t last.
Best Regards
| Life is what happens while you have another plans | |
Posted: Tue Jul 12, 2011 11:05 am |
E5GDM wrote: |
I've never heard of a timming belt sweaking. |
it will when it is over tighten
Posted: Tue Jul 12, 2011 11:55 am |
Seabook wrote: |
E5GDM wrote: |
it will when it is over tighten |
Blimey, I forgot about this thread, anyway now I know that the 'timming' belt will start 'sweaking' when it is 'over tighten'.
Thanks fellas.
Posted: Tue Jul 12, 2011 11:57 am |
| Renault Twingo 1.2 GT TCE, AP Coilovers, 25mm Hubcentric Wheel Spacers (Rear), 16" Speedline Turini Alloy Wheels, Renault Sport Cup Spoiler,, BMC F1 Panel Filter, Forge Dump Valve, Front Mounted Intercooler, K-Tec SS Cat-Back Exhaust System, K-Tec Decat Pipe, K-Tec Remap. 136.6 BHP 154.3 lbs/ft. | |
