Latest: tebas93089
Overall: 17179
Online Now [109]:
Visitors: 107
Bots: 2
Today: 82955
Total: 137753160
Forums › The Car › 206 Talk › Airbags where are they
Ruffy_206
PostPosted: Mon Jan 31, 2011 11:15 am Up
Custom - Gold Stars
i no you got two infront you two in the seats but where are the other two because so say i got 6.
the reason im asking is i need to take out my a pillars and i dont want a shock, the battery will be disconnected ect but i like to no where they are.
thanks louis
Uz
PostPosted: Mon Jan 31, 2011 11:18 am Up
The GTi 180s have Curtain airbags which are up the A-Pillar and partically along the top of the roof. But if the batterie's been disconnected correctly then you should be fine.
PostPosted: Mon Jan 31, 2011 11:23 am Up
Ruffy_206
PostPosted: Mon Jan 31, 2011 11:26 am Up
Custom - Gold Stars
aaahh ok ta. i best go steady then are the a pillars easy to get off? think they just clip on.
PostPosted: Mon Jan 31, 2011 11:37 am Up
They may well be in your B pillars just above the seatbelt slider thats where mine are
Ruffy_206
PostPosted: Mon Jan 31, 2011 11:39 am Up
Custom - Gold Stars
i thought that im sure their is an airbag sign on the pillar. hence my question im not sure and would like to no lol
PostPosted: Mon Jan 31, 2011 11:40 am Up
They'll go up round the top of the window, as curtain airbags are to protect your head in a side impact, they explode like this
PostPosted: Mon Jan 31, 2011 11:41 am Up
If you have airbags, you'll have 'Airbag' or 'SRS' stamped into it.
Ruffy_206
Custom - Gold Stars
so not in any pillar at all in the roof somewhere aslong as i go steady i sould be fine.
do the a pillars just pull off???
PostPosted: Mon Jan 31, 2011 11:43 am Up
They will be in the B pillar as said.
You should be fine to take your A pillars off just be carefull of your alarm sensors thats all
PostPosted: Mon Jan 31, 2011 5:51 pm Up
Curtain airbags run along the top edge of the roof from front to back, hidden behind the headlining.
