Posted: Mon Jan 31, 2011 4:02 pm |
Hi MrrNoName
Thanks for posting
Lee - I made a video of the startup of my 206 as I think the picture I posted might be slightly misleading
Ive noticed in the video you posted, the following lights come on when the key is turned into the second position:
STOP
What looks like Passenger Airbag
And a light next to Passenger Airbag which I cant quite make out
Please could you have a look at this video and let me know what you think?
www.youtube.com/watch?v=aUHWZae1ZHs
Thanks!
| | ![](images/spacer.gif) |
| Peugeot 206 1.4 5 door 2002 reg | |
Posted: Mon Jan 31, 2011 4:08 pm |
That seems pretty normal, the SMD might have gone for the STOP light. But if that ever came on so would the handbrake light or the EML
Posted: Mon Jan 31, 2011 4:11 pm |
Thanks Lee.
Sorry but what is an SMD?
..thanks!
Posted: Mon Jan 31, 2011 4:22 pm |
Posted: Mon Jan 31, 2011 4:29 pm |
Ah right.
Yea that was my initial thought...back when I thought there were bulbs in the instrument panel.
Do you know how easy they are to change? Are they soldered on?
When I took the Instrument panel off I noticed that each light has their own SMD... so would that explain the STOP light not coming on, but the Handbrake light coming on?
Also, you mentioed before that I may have an Airbag fault...
From looking at my video, do you still think this is the case?
Thanks alot Lee.
Posted: Mon Jan 31, 2011 4:49 pm |
Yeah they are soldered on. Each light has its own SMD.
Nah you don't have an airbag fault, from the initial picture I thought the airbag light was staying on but from the video it goes off so its all good ![Smile Smile](images/smiles/icon_smile.gif)
Posted: Mon Jan 31, 2011 4:53 pm |
Phew. Thats a relief!
How prone are the SMD's to die? Have you heard of this issue happening before?
Do you think that this is the problem in this case?
Posted: Mon Jan 31, 2011 4:58 pm |
Yeah they blow, they only have a lifetime like any other bulb. People change them to other colours as well.
If you are that worried, you could always get it fault code read and see if anything comes up.
Posted: Mon Jan 31, 2011 5:01 pm |
OK Great
Thanks Lee..
..From the link you sent me about the SMD's... I dont suppose you would know which one would be a replacement part?!
not to worry if you don't, you've been a great help anyway
cheers!
Posted: Mon Jan 31, 2011 5:08 pm |
Unplug the instrument cluster, give the plug a squirt of contact cleaner, connect it back up & try again.
You have warning lights on when you shouldnt have
Either its a dirty connection or a loss of CAN data.
Check the wiring connectors:
On the BSI:
Black 10 way connector. Terminal 8 wire 9004 and terminal 10 wire 9005.
On the instruments:
Blue 18 way connector terminal 4 wire 9004 and terminal 2 wire 9005.
I doubt the cluster is at fault, can you get someone with Peugeot Planet to test the cluster / scan the car?
Posted: Mon Jan 31, 2011 5:09 pm |
at a quick glance the startup looks pretty normal apart from the stop light.
cant check tonight but if you want il start mine up tomorrow and list exactly what lights come on which key turn so you know if any more other than the stop light arnt comming on turn two
Any work you undertake as a result of my posts is done so at your own risk ![Smile Smile](images/smiles/icon_smile.gif) | |
Posted: Mon Jan 31, 2011 5:11 pm |
Trade Rating: +36
Just looked at the video then clicked on the other one you have uploaded, Lol at him, Just waiting for him to smack his head.
Posted: Mon Jan 31, 2011 5:12 pm |
? what lol
Posted: Mon Jan 31, 2011 5:16 pm |
Trade Rating: +36
Click on His video again, On the top it says he has uploaded two video's, Check out the other one lol.
Posted: Mon Jan 31, 2011 5:32 pm |
Suicidalsoldi3r wrote: |
Click on His video again, On the top it says he has uploaded two video's, Check out the other one lol. |
Haha
Yeah that poor guy was working at the petrol garage at like 3am
