Latest: Puggingalong
Overall: 17129
Online Now [331]:
Visitors: 330
Today: 66792
Total: 101273935
Forums › The Car › 206 Talk › Permanent Live Help
Permanent Live Help
egouder
PostPosted: Tue Feb 01, 2011 2:41 am Up
Good Morning!
I am trying to install my under dashboard neons and the only supply i found was the one at the ashtray bulb which lights up with the sidelight which is not what i want exactly.
I wish to find a permanent life that will allow me to switch on the neon at the flick of a switch! I was told there is a permanent life behind the center console? where exactly? and how do i manage to get to it?
Thanks!
juanfernandes
PostPosted: Tue Feb 01, 2011 2:46 am Up
There's a guide here > How to: Footwell Neons
I haven't done it myself though.
Quote::
bertt
PostPosted: Tue Feb 01, 2011 2:47 am Up
most people just take a feed off the lighter mate
mattievrs
PostPosted: Tue Feb 01, 2011 2:48 am Up
Red wire on the headunit loom OR if your car is preplexed then the perm live on the cigarette lighter
NO LONGER ACTIVE ON THE FORUM
egouder
PostPosted: Tue Feb 01, 2011 2:50 am Up
I read all that howto more than once but i still dont know how i will get to the permanent life in the centre concole Embarassed Embarassed
I dont have a Haynes Manual either to help me out :/
Is there a simpler explanation?
egouder
PostPosted: Tue Feb 01, 2011 3:10 am Up
How do i know if my car is preplexed?
mattievrs
PostPosted: Tue Feb 01, 2011 3:17 am Up
what year is it?
To get to the perm live pull the radio out. OR unscrew the console around the handbrake. If youre not familiar with this should you be putting neons in yourself?
egouder
PostPosted: Tue Feb 01, 2011 3:25 am Up
I managed to put them with the cigarette bulb...thats not a problem but i wish to make them turn on when i want and i cant find the supply.
So your saying that if i pull my radio out i find a perm life?
mine is 1999 1.4l
thanks
mattievrs
PostPosted: Tue Feb 01, 2011 3:26 am Up
1999 will be a preplex. Get in the car and push the lighter in without the keys.It should heat up and pop out. there's your perm LIVE. Yes, pull the radio out and use the red wire coming from the back of it.
egouder
PostPosted: Tue Feb 01, 2011 3:29 am Up
ok! I think that using the lighter perm life is an easier job than the one behind the stereo...ill try that out... thanks!
Rob2859
PostPosted: Tue Feb 01, 2011 6:24 am Up
Or you can use the yellow wire on the headunit so esentially they come on when you unlock the doors and turn off when you lock them. But you will sill have the manual switch if you want. thats how mine are done
