Posted: Tue Feb 01, 2011 2:41 am |
Good Morning!
I am trying to install my under dashboard neons and the only supply i found was the one at the ashtray bulb which lights up with the sidelight which is not what i want exactly.
I wish to find a permanent life that will allow me to switch on the neon at the flick of a switch! I was told there is a permanent life behind the center console? where exactly? and how do i manage to get to it?
Thanks!
Posted: Tue Feb 01, 2011 2:46 am |
Quote:: |
Haven't got a pic but we all know what they look like. |
Being the picky sort - I really hate it when people say this. Yes we all know what it looks like - but we all want to see the condition that yours is in! | |
Posted: Tue Feb 01, 2011 2:47 am |
most people just take a feed off the lighter mate
Posted: Tue Feb 01, 2011 2:48 am |
Red wire on the headunit loom OR if your car is preplexed then the perm live on the cigarette lighter
| NO LONGER ACTIVE ON THE FORUM | |
Posted: Tue Feb 01, 2011 2:50 am |
I read all that howto more than once but i still dont know how i will get to the permanent life in the centre concole
I dont have a Haynes Manual either to help me out :/
Is there a simpler explanation?
Posted: Tue Feb 01, 2011 3:10 am |
How do i know if my car is preplexed?
Posted: Tue Feb 01, 2011 3:17 am |
what year is it?
To get to the perm live pull the radio out. OR unscrew the console around the handbrake. If youre not familiar with this should you be putting neons in yourself?
Posted: Tue Feb 01, 2011 3:25 am |
I managed to put them with the cigarette bulb...thats not a problem but i wish to make them turn on when i want and i cant find the supply.
So your saying that if i pull my radio out i find a perm life?
mine is 1999 1.4l
thanks
Posted: Tue Feb 01, 2011 3:26 am |
1999 will be a preplex. Get in the car and push the lighter in without the keys.It should heat up and pop out. there's your perm LIVE. Yes, pull the radio out and use the red wire coming from the back of it.
Posted: Tue Feb 01, 2011 3:29 am |
ok! I think that using the lighter perm life is an easier job than the one behind the stereo...ill try that out... thanks!
Posted: Tue Feb 01, 2011 6:24 am |
Or you can use the yellow wire on the headunit so esentially they come on when you unlock the doors and turn off when you lock them. But you will sill have the manual switch if you want. thats how mine are done
