Latest: Puggingalong
Overall: 17129
Online Now [287]:
Visitors: 286
Today: 14028
Total: 101221219
Forums › The Car › 206 Problems › Instrument Panel / Speedo / Dashboard Lights
Go to page Previous  1, 2, 3
kevinkeady
PostPosted: Mon Jan 31, 2011 5:33 pm Up
MrrNoName wrote:
at a quick glance the startup looks pretty normal apart from the stop light.
cant check tonight but if you want il start mine up tomorrow and list exactly what lights come on which key turn so you know if any more other than the stop light arnt comming on turn two
Hey, yeah that would be great if you could, Id really appreciate it
Thanks mate!
Peugeot 206 1.4 5 door 2002 reg
kevinkeady
PostPosted: Mon Jan 31, 2011 5:37 pm Up
MrBSI wrote:
Unplug the instrument cluster, give the plug a squirt of contact cleaner, connect it back up & try again.
You have warning lights on when you shouldnt have Confused
Either its a dirty connection or a loss of CAN data.
Check the wiring connectors:
On the BSI:
Black 10 way connector. Terminal 8 wire 9004 and terminal 10 wire 9005.
On the instruments:
Blue 18 way connector terminal 4 wire 9004 and terminal 2 wire 9005.
I doubt the cluster is at fault, can you get someone with Peugeot Planet to test the cluster / scan the car?
Hey MrBSI
Thanks for posting.
When you said I have warning lights on when I shouldn't have, what are you referring to?
Also, I'm new to all this, what does BSI stand for? And what is Peugeot Planet? I realise I sound like a proper newb!
thanks again!
MrrNoName
PostPosted: Wed Feb 02, 2011 2:54 am Up
As requested in your PM
Dash lights for a 2001 (pre-mux) 206 LX
Key in = no lights
Position 1 = Battery light
Position 2 = Airbag, Fuel spot, engine, battery, Oil, Handbrake, Stop light
Position 3 (engine running)= No lights
NOTE: except the handbrake light if its applied, and Airbag light for a few seconds ( if the key is turned from position 2 to position 3 quickly, the airbag light hasnt had chance to go out yet)
probs what made lee think you had a airbag fault initially
EDIT: just had a look at your video again, looks like your oil and stop light arnt working Razz
kevinkeady
PostPosted: Wed Feb 02, 2011 1:29 pm Up
Key in = no lights
Thats great, cheers for doing that mate.
Right... better get learning how to solder then!
Page 3 of 3
