Posted: Wed Feb 02, 2011 2:13 pm |
i was hoping that would be the case. going to have a look around now for some hose on ebay as it is only the piping that is broken.
Posted: Wed Feb 02, 2011 2:15 pm |
kev85 wrote: |
any ideas on the oil around the spark plugs.
car has not been running well recently with the engine management light coming on the other day. tried to start it up today and it would not fire up, managed to eventually but only just. just wondering if they are all interlinked.
drunknmunky do you know anywhere decent to get the codes read in blackburn so i can see whats wrong with my car.
cheers |
more than likely be the rocker cover gasket thats leaking.
| NO LONGER ACTIVE ON THE FORUM | |
Posted: Wed Feb 02, 2011 2:28 pm |
the thing is with k&n filter is quite expensive, not to mention you have to buy the cleaning fluid and oil it every time after you clean it :/
Posted: Wed Feb 02, 2011 2:31 pm |
Seabook wrote: |
the thing is with k&n filter is quite expensive, not to mention you have to buy the cleaning fluid and oil it every time after you clean it :/ |
If you're using the full cans on your filter, then you're using way too much
The cleaning kit should last you a long time.
Posted: Wed Feb 02, 2011 2:38 pm |
I've had a K&N cleaning kit for 5 years. It's not even half used yet!
Posted: Wed Feb 02, 2011 2:41 pm |
the oil last a long time but the cleaning fluid is running out quite fast
Posted: Wed Feb 02, 2011 2:51 pm |
rocket cover gasket..another thing i will have to look into then and more importantly price up.
as for the k&n as long as the cleaning kit isn't too expensive and lasts a couple of years it should end up working out about even. will have to look into it and decide as probably only have the car another 2 years at most, probably less with all thats going wrong with it!!!!!
