Online Now [987]:
Visitors: 986
Today: 231169
Total: 148985862
Forums › The Car › 206 Problems › PLEASE HELP WITH THIS IF YOU CAN GUY'S !!
ryanrox
PostPosted: Wed Feb 02, 2011 8:02 pm Up
right guys ive had this really annoying sound comming from my driver's side wheel for the past few month's , it is a like high pitch sound going to the momentum of the wheel
when i apply the brake the sound turns into a crunching noise , very noticeable when breaking at lights /slowing down
i have had my pads and my bearings changed but still the noise continues and it is doing my nut in !
guy at the garage i use said its the actually hub its self but i have given the car to another garage and they it is the driveshaft :s
i personally myself took the wheel off and spun the section around, i noticed the noise happens once per 360 spin on the same section every spin if that makes any sense what so ever
i'm not really good with car's just an amazing driver ahah (i wish)
if anyone has any clue what is it i would be really grateful as i feel garages are just trying to mug me off
thanks
Ryan McCarthy
L5_UKS
PostPosted: Wed Feb 02, 2011 8:14 pm Up
Sounds like your driveshaft to be honest buddy. would get it sorted before it gets worse, broken driveshafts can cause the car to shake and make the car unsafe.
-Dave-
Trade Rating: +36
I had a warped disc which caused me something like that a while ago. Not saying that's what is wrong with your's but I heard about three different diagnosis before I found the issue.
Ex 206 Owner.
ryanrox
PostPosted: Wed Feb 02, 2011 8:27 pm Up
yer when i seem to brake it seems to shake quite vigarously when going from high speeds
if it is the driveshift how much you reckon i'm looking?
suicidalsoldi3r did you have similar noises? one guy at the garage did say i have a like dip in my brake disk
Ryan McCarthy
-Dave-
PostPosted: Wed Feb 02, 2011 8:32 pm Up
Trade Rating: +36
It squeaked as the disc rotated and and when the brakes were applied it got louder, But the wheels also shuddered as I broke which was strong enough to feel back though the steering. If the garage said you have a dip you should change them anyway then see if there is any difference.
Ex 206 Owner.
perry081064
PostPosted: Wed Feb 02, 2011 8:34 pm Up
my bro in law had this .. for him it was new discs n pads.
206 2.0 HDI
M60SHW
PostPosted: Thu Feb 03, 2011 4:46 am Up
I had this, put a new driveshaft in and was still doing it for about a week then just stopped was really random haha never bothers trying to figure it out lol it's just French Smile
Team, ST
Team, Gti 138 track slag
Werdnal
PostPosted: Thu Feb 03, 2011 5:47 am Up
Warped or worn discs?
I had a problem in a previous car where the disc was worn, and the lip on the edge of the disc was scruffing on the pad.
hotham15
PostPosted: Thu Feb 03, 2011 7:28 am Up
I'm joining the 'warped disc' crew. I had the same noise and changing the discs fixed it. A cheap fix you can do yourself too Smile
GTi 180 - Black - GP04 *** - Standard + Typhoon, CL5+ Breaks & Front Splitter.
my1st206
PostPosted: Thu Feb 03, 2011 7:40 am Up
I have a grinding sound aswell, i tried new pads and discs and then about a month later there is a slight grinding noise again as though the discs need replacing again. I felt the brake discs and there is already a slight lip on them, is that right after about a month??
2003 1.1 Look
stevedude
PostPosted: Thu Feb 03, 2011 10:16 am Up
cheap pads?
caliper not releasing proper?
Happydays
leigh_boy
PostPosted: Thu Feb 03, 2011 3:29 pm Up
drive shaft, loose wheel , disc or wheel bearing Smile
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
ryanrox
PostPosted: Thu Feb 03, 2011 7:47 pm Up
Thanks guys, guy at garage reckons it is defiantly the hub, so is replacing that and if the disks are worn or warped then getting them replaced too, hope this sorts out this bloody noise! Apart from this the car has been a lil gem!
Ryan McCarthy
ryanrox
PostPosted: Wed Feb 16, 2011 8:05 pm Up
yayyyyyyyyyyyyyyyy no more noise Smile was the hub i dont know what was wrong with it but had to get a new one:)
Ryan McCarthy
