Latest: tebas93089
Overall: 17179
Online Now [96]:
Visitors: 95
Today: 27713
Total: 138501358
Forums › The Car › 206 Problems › 206 S REG CUTTING OUT
wallace
PostPosted: Wed Feb 02, 2011 5:59 am Up
got a 206 1.4 last year S reg great car no problems until now
the car just cuts out .I pull up turn ignition off then re start .The car starts ok but then cuts out again this can happen up to 4 / 5 times then everything is ok and I can carry on . never know when this is going to happen . Has anyone else had this problem ?? I cant work it out . Thanks
Quarmbo
PostPosted: Wed Feb 02, 2011 6:21 am Up
Have you tried any of the suggestions on your previous post? Which is exactly the same as this one? Just bump your previous thread.
Ford SportGay-A
Danny.
PostPosted: Wed Feb 02, 2011 6:45 am Up
www.206info.co.uk/Foru...23616.html
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
wallace
PostPosted: Wed Feb 02, 2011 7:01 am Up
Sorry didnt know same threads new to this .
not tried the throttle valve yet needed to see if there were any other ideas first .I have taken it into a peugot specialist for a diagnostics
see what they come up with will post response . thanks
wallace
PostPosted: Thu Feb 03, 2011 8:27 am Up
Just had the diagnostics results back , seems to be the stepper valve ?
£ 90.0 fitted .
Kersh
PostPosted: Thu Feb 03, 2011 8:42 am Up
stepper valve is the idle control valve..
as was said in your previous topic
Member number: 36
wallace
PostPosted: Thu Feb 03, 2011 8:55 am Up
OK thanks kersh I will look at that
Kersh
PostPosted: Thu Feb 03, 2011 9:24 am Up
should be able to pick a used one up for about 20 - 30 quid. then they are very easy to fit
Member number: 36
