Online Now [1034]:
Visitors: 1034
Today: 278967
Total: 149030106
Forums › The Car › 206 Problems › Emissions
Emissions
sirus
PostPosted: Mon Jan 31, 2011 3:49 pm Up
my pug 206 1.1 failed its MOT on the emissions and they a pin pointed it down to one of the injectors stayin open for to long. if i was to replace one of the injectors would that be ok or would u need to replace all 4?
Own Pug 206
SDK206
PostPosted: Thu Feb 03, 2011 4:41 pm Up
very strange, good diagnosis and strange it was only picked up at MOT.
but if that is the fault it should cure it as that would screw up the fuelling and also emissions but make sure they are certain before fitting new parts
you would be ok with fitting 1 but while they are accessible maybe do the lot, your call really
If in doubt, drop a cog and put your foot down Smile
giveitsomebar
PostPosted: Fri Feb 04, 2011 2:29 pm Up
do you have the sheet which says it failed emission as that will tell you how much it failed by and in what department i cant see how they can say an injector is staying on to long as it would be very hard to tell and a garage wouldnt do it on an mot 9/10 a car fails emmision because of a leaky exhaust joint !
