Posted: Sat Feb 05, 2011 3:28 am |
does anyone know where it is on a 2l 2003 hdi because i think it needs changing
and is it expensive or even neccesary??
regards
jonah
Posted: Sat Feb 05, 2011 3:40 am |
Its under the drivers side windscreen. As you look in the engine bay, along the top left hand side, just under the screen. I have no idea if its necessary but im changing mine today, going to pop to Halfrauds to get it.
Posted: Sat Feb 05, 2011 3:44 am |
They should be changed every year ideally.
Posted: Sat Feb 05, 2011 3:45 am |
If you get it off egay it's cheap as chips. Do it when you service the car, its always nice getting fresh, non-mould-spore air coming into the car
shop.ebay.co.uk/i.html...m270.l1313
| Hi Mikey
Posted: Sat Feb 05, 2011 3:46 am |
should be changed same time as oil change , only about £7 and easy to change.
There is a how to ... on here on this .
| New car 2011 / Thoruim grey , 207 1.4 Vti 16v Sport 95bhp , tinted rear windows.
Old car 2000/ 206 2.0 hdi. | |
Posted: Sat Feb 05, 2011 3:51 am |
lol
mine hasnt been changed for 7 years!!
Get it changed
| Hi Mikey
Posted: Sat Feb 05, 2011 3:54 am |
sillyhilly wrote: |
Get it changed  |
Best to do on your service if you do it yourself, i shall be doing that on my days off next week
Posted: Sat Feb 05, 2011 4:18 am |
They are visibly dirty after 12 months so after 7 years they'd be minging!
Posted: Sat Feb 05, 2011 4:29 am |
Posted: Sat Feb 05, 2011 4:31 am |
o dear 7 years lol,
i do mine every 5 months
Posted: Sat Feb 05, 2011 4:58 am |
will post up a pic when i get it out
