Posted: Sat Feb 05, 2011 10:15 am |
Anyone know what size this should be? I had a new exhaust fitted back in 2008 a a year later this joint was loose. Took it back to the exhaust fitter and they changed the clamp.
They also had to grind a small bit off the end of the centre pipe flange because it was stopping it sealing properly.
Now it's loose again and it MOT runs out at end of month ...
I want to fit a new clamp, but I can't see any marks on the old one to find out what size it is.
Any ideas? Thanks!
Posted: Sat Feb 05, 2011 10:33 am |
54mm
Part number 1713 67 @ £5.71
Posted: Thu Feb 17, 2011 2:49 pm |
Cheers ... sorry haven't been on much since I posted .. mainly in the garage prepping the 206 for the MOT!
Turns out the clamp was loose ... how I don't know I watched a guy twice my size do up the nuts with a socket and torque wrench ... and it was really tight!!!
So two new rear tyres today, a tie-wrap around one CV joint boot that had lost its clamp ring!!!, the exhaust and a good clean ... fingers crossed!!
Posted: Sat Feb 19, 2011 10:06 am |
Well it all worked .. one more pass!!
Posted: Sat Feb 19, 2011 11:01 am |
gazza82 wrote: |
Well it all worked .. one more pass!! |
gratz
