Online Now [313]:
Visitors: 312
Today: 26758
Total: 143153250
Forums › The Car › 206 Problems › Fuel gauge stuck !
Fuel gauge stuck !
kerry
PostPosted: Wed Feb 02, 2011 1:42 pm Up
Hello Went to get fuel yesterday had 3/4 of a tank, filled it up to the 2nd click got back in and the gauge is still on 3/4 hasn't moved up to the full mark at all have tried turning car on and off and leaving it over night made no difference, any ideas????
Also car only doing 24 m.p.g surely this can't be right for a 1.4 8v petrol
Peugeot 206 1.4 petrol 53 reg
elcamino
PostPosted: Wed Feb 02, 2011 2:25 pm Up
Level transmitter stuck somewhere try shake the car from beside!
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
PostPosted: Wed Feb 02, 2011 2:28 pm Up
What He Said
if this didn't work,then you need to take it out from the tank
PostPosted: Wed Feb 02, 2011 2:38 pm Up
Does it stay there even when the car is off?
If it doesn't, try rebooting the BSI
kerry
PostPosted: Wed Feb 02, 2011 3:03 pm Up
when you turn the car off needle drops back down to empty turn it back on and it goes to 3/4.
What is the BSI??
PostPosted: Wed Feb 02, 2011 3:04 pm Up
206info.co.uk/Forums/v...20541.html
elcamino
PostPosted: Wed Feb 02, 2011 3:07 pm Up
This happened to me.i left the car with 3/4 for some days and when i filled it to full,gauge did not move.i tuned it off then on but it came up from zero to 3/4.shook the car when it was off then i turned it on and gauge came up to full. Smile
kerry
PostPosted: Wed Feb 02, 2011 3:15 pm Up
I will try that, is it worth getting friend to plug it into Snap on computer thing and see if there is a fault ??
kerry
PostPosted: Sun Feb 06, 2011 10:55 am Up
UPDATE !! Have just filled car back up as gauge had dropped to nearly 1/2 tank again its click to say full but gauge still down on 1/2 tank, I am really starting to not like my car grrrrrrrrrrrrr its also still only doing 24 mpg !!
PostPosted: Sun Feb 06, 2011 11:01 am Up
This happened to me once. As you know you know you have a full tank, youve got at least 300 miles in it, drive it until youve done 300 miles and the needle should drop, fill it back up and see what happens.
When this happened to me, i had a full tank, but when i started my car it had dropped to 3/4. Drove till the needle dropped and refilled.
leigh_boy
PostPosted: Sun Feb 06, 2011 1:10 pm Up
seen this problem a few time, normaly the float on the fuel pump has got fuel isn't it and is not giving a correct reading, you have 2 options,
disconnect the wiring and get another pump from some wer and then lift up the level and see what it reads on the clock or 2. get a drill and remove the rivits on the fuel pump cover and take it out and test it with out buying another 1,
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
kerry
PostPosted: Tue Feb 08, 2011 12:00 pm Up
What a nightmare today have taken out the fuel pump, car had much more fuel in it than we had thought ended up filling up the bowl shape thing that the pump sits in then running out all over the floor Ouch,managed to save about 35 litres into cans !!!!! took it out cleaned the sender unit and re fitted it had to then use the car to go to a friend who had a pump to put fuel back in it, driving along car stopped so i got out and petrol so pouring out from under the car , lifted back seat and the vacuum pipe had come off put it back on and the car started leaving big puddle of petrol on the floor.
On the good point after putting the rest of the saved petrol back in gauge is working again Smile
Thankyou for all your replies , also hoping if the sender was stuck, car might not be so bad on fuel as i was thinking !
giveitsomebar
PostPosted: Tue Feb 08, 2011 12:10 pm Up
glad you got it sorted it reminded me of a time when i had a petrol leak on a car and i thought the tank had split and the breathers were blocked so after leaving it leaking down the drive all night i took the fuel cap off started stripping it down to remove the tank and my dad decided to blow down the breather i got fuel in my hair mouth eyes nose bassically showered me in it (stings like mad when its in your eyes!) anyway the next day come an i decided to take the tank out on my own undone everything couldnt get it out then give it a shuffle and it drops on me chest nearly breaking my ribs and the bloody thing was virtually full up to the brim!!
Laughing ended up it wasnt leaking just been over filled! what a doughtnut i felt!
