Online Now [86]:
Visitors: 85
Today: 64553
Total: 117628116
Forums › The Car › 206 Talk › Long locking wheel bolts?!?!??
Go to page Previous  1, 2, 3, 4
PostPosted: Sun Feb 06, 2011 12:37 pm Up
no you need 35mm taper bolts. standard ta[er bolts is 25mm
use PugJH that website, choose the alloy manufactorer and then choose 206 fitment.
MrrNoName
PostPosted: Sun Feb 06, 2011 12:47 pm Up
lol huh, at the moment the bolts i have in my hand are
tapered, with a 60 degree angle. and have a 35mm thread length
they give me approx 16mm INSIDE the hub. 14mm is taken up by the wheel and spacer. i thought they were too short lol
EDIT: i understand what your saying, standard fitment is 25mm tapered or 35mm flat, so with 10mm spacers 35mm tapered should work
but i dont know if this is correct. it might be that its 35mm because the alloys thicker. and the fact that its flat is irrelevant. if this is the case 35mm tapered would be too short for me with the 10mm spacers
PostPosted: Sun Feb 06, 2011 12:58 pm Up
the hubs won't take more than 15mm thread.
MrrNoName
PostPosted: Sun Feb 06, 2011 12:59 pm Up
good call. this true? Razz doesnt seem very much
surely that cannot be correct because even with 25mm bolts and steelies, about 20mm would be in the hub. steelies arnt very thick about 5mm maybe
MrrNoName
PostPosted: Sun Feb 06, 2011 1:42 pm Up
anyone else got any input on what length bolts i need lol
PostPosted: Sun Feb 06, 2011 2:58 pm Up
May be a bit late, but I bought mine off gavstar with 20mm spacers and he looked into locking bolts but he would have had to have them made up specially and would have cost so much it just wasn't worth it.
PostPosted: Sun Feb 06, 2011 5:53 pm Up
i am running pug sport wheel stud at the moment and they only have 15mm thread on the hubs side.
MrrNoName
PostPosted: Mon Feb 07, 2011 10:53 am Up
just been out there and checked physically myself
original steel wheel bolts screw in 11 rotations
new extended alloy wheel bolts with spacers on + new wheel screw in 12 rotations
35mm is correct for 10mm spacers with tapered bolts
Razz the new bolts screw in exactly the same distance as the old ones! a bit further if anything!
seabook, you were correct throughout this lol
PostPosted: Mon Feb 07, 2011 11:42 am Up
glad you finally sort this Smile
Page 4 of 4
