Latest: jackrox1992
Overall: 17186
Online Now [711]:
Visitors: 710
Today: 110443
Total: 148639309
Forums › The Car › 206 Problems › thrust bearings
thrust bearings
sp5flys
PostPosted: Mon Feb 07, 2011 3:49 am Up
my 206 is started making a hell of a nosie squealing i can feel a vibrating on the clutch when im driving after a while off driving its starts smoking a little, it still go in gear ok and still pull away good, does anyone know what it is? how much it cost? cheers
.. Peugeot 206 2.0 D turbo hdi ..
kieron
PostPosted: Mon Feb 07, 2011 3:58 am Up
A clutch kit will be around £100 then you got garage fees on that or do it yourself
when you are staionary with the clutch out is they a rattle? and when you push it in will it go away? if so its the release bearing
Account suspended
Kersh
PostPosted: Mon Feb 07, 2011 3:59 am Up
to change the thrust bearing you have to remove the gearbox.. which is expensive.
sounds like thrust bearing to me
Member number: 36
sp5flys
PostPosted: Mon Feb 07, 2011 4:18 am Up
hi when i depress the clutch the vibration gets more intence but its still depressing ok, if its a dual mass clutch would it be more money? thank you
