Latest: SA01
Overall: 17138
Online Now [4138]:
Visitors: 4137
Today: 85160
Total: 111399512
Forums › The Car › 206 Talk › Brake Advice
Brake Advice
Liam-HuTcH
PostPosted: Mon Feb 07, 2011 12:23 pm Up
East Area Rep - Liam-HuTcH
Was wondering if these are a good combination together?
as my car will be having Gti calipers fitted but want a good decent brake set to go with it.
cgi.ebay.co.uk/Front-B...5d2c95f3ae
cgi.ebay.co.uk/BREMBO-...56359f6b25
Regards
Team: Smashed Up Firedance
Team: Black 206
PostPosted: Mon Feb 07, 2011 12:24 pm Up
make sure you got the correct fittment as there is 2 tyres of fittment for gti brake
Liam-HuTcH
PostPosted: Mon Feb 07, 2011 12:25 pm Up
The gti Brakes i have are same as the ones on a 2.0 hdi or d-turbo. if that matters
Team: Black 206
kieron
^^^^^^ I made that fault when i got mine they was 2 types of pads and 2 different gti calipers
Account suspended
PostPosted: Mon Feb 07, 2011 12:27 pm Up
Yep, discs & pads are different on both versions. Different offset on the discs & pads are shaped differently
PostPosted: Mon Feb 07, 2011 12:28 pm Up
you need to know whether you got the lucas calipers or bosch calipers
Liam-HuTcH
PostPosted: Mon Feb 07, 2011 12:33 pm Up
bosch
Team: Black 206
richpowell91
PostPosted: Mon Feb 07, 2011 12:39 pm Up
If they are the right discs they are £10 cheaper on nextdaybrakes.com with free next day delivery Wink
Liam-HuTcH wrote:
bosch
which year?
99 to 01 most likely is still using the 266x20.5 disc
02 or newer will use the 266x22 disc
Liam-HuTcH
PostPosted: Mon Feb 07, 2011 12:52 pm Up
they were off a 2004 plate hdi
Team: Black 206
PostPosted: Mon Feb 07, 2011 1:00 pm Up
then most likely you need the 266x22 disc, not the one in your link
PostPosted: Thu Feb 10, 2011 11:41 am Up
Sorry for the hijack. How can you tell if you have Bosch or Lucas braking system?
PostPosted: Thu Feb 10, 2011 11:42 am Up
Whats your VIN?
PostPosted: Thu Feb 10, 2011 11:58 am Up
Lee wrote:
Whats your VIN?
pm'd
The reason I ask is I have a horrible grinding noise when I brake. Only happens for first half mile then goes. Sounds like coming from the back, and the handbrake is 10 clicks, which makes it sound like brake adjustment or worn shoes. Don't fancy stripping only to find I have to rebuild to go get some new shoes to come back and fit them. Might as well have them ready.
