Online Now [85]:
Visitors: 84
Today: 20393
Total: 138755724
Forums › The Car › 206 Talk › Mods vs Maintainance
PostPosted: Mon Feb 07, 2011 4:32 pm Up
remove everytihng that can be removed on the car, empty the windscreen washer, put just enough petrol in, loss your weight....etc
Andy180
PostPosted: Mon Feb 07, 2011 4:51 pm Up
Quote::
use 99 ron petrol
wouldnt bother it will do absoloutley jack s**t on a 1.4
GTI 180
Andrew
PostPosted: Mon Feb 07, 2011 4:52 pm Up
Mattie-DS3 wrote:
All else fails let me race him Wink
Do I need to put a pot noodle gti into my glovebox to turn it into the DS3 then?
My 206 thread
www.detailedbyandrew.com
Luke
PostPosted: Mon Feb 07, 2011 5:05 pm Up
Green Cotton panel filter, performance HT leads, decent spark plugs, new rotor arm and dizzy cap, high grade oil, K&N oil filter, EBC Green Stuff brake pads, new discs and brake fluid, new soft compound tyres, lose the back seats and any excess weight.
That should set you in good stead with just service parts.
PostPosted: Mon Feb 07, 2011 5:06 pm Up
Luke he doesnt on a porchse Laughing
No HT leads, rotor arm or dizzy cap Laughing
PostPosted: Mon Feb 07, 2011 5:11 pm Up
why do you need new brake pad, disc and fluid for 1/4 miles? lol
Luke
PostPosted: Mon Feb 07, 2011 5:12 pm Up
Stupid coils! Embarassed Tells you the last time i did any work on the 206.
Buy some anyway!!
wardie_206
PostPosted: Mon Feb 07, 2011 5:33 pm Up
accidently drop a 1.6 8 valve in urs, everything will be standard just the engine size has increased :D!!
serious note: all of the above to be fair, try to make it as light as possible and get your start off to a tee.
could also look at taking the restictive part of the airbox off, the part that goes up and over the wheel arch, and putting a small pipe on the bottom of the airbox. might give u a little gain.
Andy_VXR
PostPosted: Mon Feb 07, 2011 5:36 pm Up
Andy180 wrote:
Quote::
use 99 ron petrol
Make the car run smoother and clean the insides out Wink
ARDEN BLUE ASTRA VXR - 19s In Anthracite, Cruise Control, Tints, Priv. Reg, Remus, Stage 2
Other half - 1.4 206 lx
Rob2859
PostPosted: Mon Feb 07, 2011 5:46 pm Up
He is right. I took that pipe away and ran a plasic pipe to the corner of my bumper over the ledge of the wheel arch, it does give a noticable improvment, cost me £5 for the pipe from B&q. You will need flexi pipe too though for the bend. Don't put it to the front of the bumper though as it just causes over-pressure and makes the fuel run lean. Cotton pannel filter needs to be included with the service. they are only like 30 quid.
I would also lower your tyre pressures a bit
M60SHW
decent tyres are a must see if you can get some good make part warns for a few quid and a spare set of front wheels to use for race day paint them in luminus green adds 24.3 bhp "proven"
Team, ST
Team, Gti 138 track slag
meady
PostPosted: Mon Feb 07, 2011 5:53 pm Up
Trade Rating: +45
why lower the tyre pressure, thts just going to make the tyrs a bit more flat and mean there will be more resistnace. you want to up them a bit if anythinmg as there will be slightly less friction on the road which will help out Smile
TEAM - I HATE FACEBOOK Smile
M60SHW
PostPosted: Mon Feb 07, 2011 6:01 pm Up
www.youtube.com/watch?v=vrKPPdTuk8I
go to 5 mins lol Razz
Rob2859
PostPosted: Mon Feb 07, 2011 6:04 pm Up
wider surface area so they will be grip better on the start.
pedro_keil
PostPosted: Mon Feb 07, 2011 6:15 pm Up
Have a number 2 before take off LOL!!
Didn't want to say Poo Wink thought it might seem rude lol
Now revived!!: 2001 206 Moonstone Dturbo (ungoing some more TLC!!)
Current daily driver: 2007 Citroen C4 Coupe 1.6 HDi VTS - used and abused
Weekend driver: 2006 VW Eos 2.0 TFSi - Woooooooossssshhhhhh!!!!
Page 2 of 4
