Latest: Puggingalong
Overall: 17129
Online Now [354]:
Visitors: 353
Today: 41779
Total: 101166550
Forums › The Car › 206 Problems › clunking from rear..
wasp
PostPosted: Tue Feb 08, 2011 3:27 am Up
Hi all
I have just bought a 206sw 1.4hdi which has a very annoying clunk from its rear end.
If checked the following:
radius arm bearings no play at all (have reciept for them being replaced last year)
wheel bearings all ok.
spare wheel carrier - removed - still clonking!
rear shocks removed,(almost got sea sick on road test Smile still clonking
tightened arb..still clonking
removed arb !...still clonking
beam mounts look ok...even when pryed with crowbar!
rear tailgate open -still clonking on road test
exhaust -perfect, cannot hit anything...
if i have rear passengers (my two children) then NO noise!
checked rear seatbelts , rear seats folded ..still clunks
this clunk only seems to happen on bigger potholes.
no different on cornering etc etc.
rock the car at rear from side to side...no noise
PLease Please if anyone can shed some light!
Dave
206sw1.4hdi
ma.langan
PostPosted: Tue Feb 08, 2011 5:03 am Up
My first car had a loud clunk noise that sounded like it was coming from the rear, but it was actually coming from the front and was the drop links for the anti roll thing. Take your front wheel off and wiggle kick and knock them to see if they are worn or make the same sound. if it is the drop link they are about £10 to replace your self and your car wont fail its mot Smile
Farmer T'aaron!
wasp
PostPosted: Tue Feb 08, 2011 3:45 pm Up
ma.langan
Thanks for that, ill have a look at the weekend.
the noise is driving me bonkers
Dave
206sw1.4hdi
PostPosted: Tue Feb 08, 2011 5:21 pm Up
trailing arm bearings, wheel bearing, loose wheel cage, and iirc sw had the extra arms on the rear beam, check them too.
Rob2859
PostPosted: Tue Feb 08, 2011 6:20 pm Up
Maybe the bolts holding the rear seats in? They go right through the floor so could make quite a noise if loose
wasp
PostPosted: Wed Feb 09, 2011 2:19 pm Up
Thanks to all ill have look..and report back
206sw1.4hdi
