Posted: Tue Feb 08, 2011 5:59 pm |
I failed at ggetting my drum off today. Was trying to inspect the shoes because I am getting a metal to metal noise and the front pads are fine.
I took the nut off and the washer. Then I gave it a tug. It should have just slid off but nooooo.
I thought maybe the brakes were binding slightly so I slackened off the handbrake to no avail. I tried to hammer and chisel it off but again nothing. I also put 2 wheel nuts in and tried to pull it but it didn't budge.
Posted: Tue Feb 08, 2011 6:02 pm |
Loosen the big nut put the wheel back on and kick the tyre
Left to right, up down etc
That sometimes does the trick
Posted: Tue Feb 08, 2011 6:05 pm |
yeah put the wheel on an give it a proper kicking it will come off with some brute force
Posted: Tue Feb 08, 2011 6:13 pm |
I thought it wouldn't be on the tight. didn't want to break it. To be fair I was giving it some big hits with the hammer from the back of the drum and it didn't seem to more at all. loads of rust fell off though
Posted: Tue Feb 08, 2011 6:17 pm |
put the wheel on and kick it from underneath, seems to happen on 206's quite offen. if you got the one side off do they need replacing? if so kick it off as the worst that can happen is the shoe clips fall off and the shoes fall apart
Posted: Tue Feb 08, 2011 7:50 pm |
giveitsomebar wrote: |
put the wheel on and kick it from underneath, seems to happen on 206's quite offen. if you got the one side off do they need replacing? if so kick it off as the worst that can happen is the shoe clips fall off and the shoes fall apart |
or the car off the jack
Posted: Wed Feb 09, 2011 2:33 am |
Rob2859 wrote: |
or the car off the jack  |
lol
Any work you undertake as a result of my posts is done so at your own risk  | |
Posted: Wed Feb 09, 2011 4:53 am |
hopefully you would put an axle stand under it before hand i didnt think anyone would be stupid enough to start shaking a car while its on a scissor jack!
Posted: Wed Feb 09, 2011 4:54 am |
hopefully you would put an axle stand under it before hand i didnt think anyone would be stupid enough to start shaking a car while its on a scissor jack! |
i wouldnt ever use a sissor jack anyway.
had two collapse on me
Posted: Wed Feb 09, 2011 7:19 am |
big hammer and a crow baw if its stuck and make sure your not being silly and got the hand break on lol seen some 1 do it before
| *DEAD*206 Gti 138
Toyota Celica T sport 205 BHP | |
