Latest: Kifi69
Overall: 17183
Online Now [458]:
Visitors: 458
Today: 43506
Total: 144061415
Forums › The Car › 206 Problems › Handbrake light..
Handbrake light..
MutilateTheDead
PostPosted: Wed Feb 09, 2011 5:38 am Up
As soon as i pull off in my car after first starting up and taking the handbrake off the handbrake light comes on, i have noticed a lot of brake dust build up on the rear alloy (driver side) after most journeys 10 miles+, is the handbrake rubbing maybe? there isn't any noise Confused
206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out!
PostPosted: Wed Feb 09, 2011 5:52 am Up
maybe low fluid, maybe due to low brakes??
some cars have low brake warning light unsure if the 206 has one (i know lower ends dosnt)
MutilateTheDead
PostPosted: Wed Feb 09, 2011 6:01 am Up
Checked my brake level and its all fine Confused
giveitsomebar
PostPosted: Wed Feb 09, 2011 6:06 am Up
this gets covered most weeks, take the console from round the handbrake and there will be a switch under there check that is all plugged in
MutilateTheDead
PostPosted: Wed Feb 09, 2011 6:10 am Up
Nice one, will check when i get home, thanks
sillyhilly
PostPosted: Wed Feb 09, 2011 6:19 am Up
The light flashes when the pads are low as well... Also check them.
Hi Mikey Smile
MutilateTheDead
PostPosted: Wed Feb 09, 2011 6:21 am Up
Good point too, due for a service! Cheers guys
