Online Now [724]:
Visitors: 724
Today: 202950
Total: 146657826
Forums › The Car › 206 Talk › Is it safe too drive with a noisy wheel bearing?
Forum Index › 206 Talk
pudmonkey
PostPosted: Wed Feb 09, 2011 3:10 am Up
As per the title, drivers side bearing is howling, getting it fixed on Monday afternoon but still need to drive to and from work (20 miles each way) for the rest of the week. Noise has been getting steadily worse over the last week and i dont want to run the risk of the whole hub getting damaged.
PostPosted: Wed Feb 09, 2011 3:17 am Up
Short answer-
No
pudmonkey
PostPosted: Wed Feb 09, 2011 3:22 am Up
Cool thanks, will just park it up until Monday then and try to organise a lift with someone for this week.
Just wanted to make sure i wasnt making a mountain out of a mole hill!
giveitsomebar
PostPosted: Wed Feb 09, 2011 6:15 am Up
sometimes they can last for ages making a noise but i wouldnt risk it if it fails it will either lock your wheel solid or the wheel will fall off!
pudmonkey
PostPosted: Wed Feb 09, 2011 6:43 am Up
Yah really not worth the risk imo, knowing my luck it would go wrong aswell.
JDave
PostPosted: Wed Feb 09, 2011 7:33 am Up
My bearings were goosed as well. Its not safe because the pressure of driving is on the wheel at unusual angle, so if you keep going your wear will be uneven. All it takes is a pot hole and boom, its even worse
Click To View My Project
gti180boy
PostPosted: Wed Feb 09, 2011 4:44 pm Up
Shoulded really drive it. unless you going to a garage near you to get it fixed.
If it completely goes then you could do alot more damage and cost more to fix it.
Smile
180 Doctor
PostPosted: Wed Feb 09, 2011 4:45 pm Up
Did about 500 miles on my mine Laughing
Lecktorious
PostPosted: Wed Feb 09, 2011 5:19 pm Up
Trade Rating: +59
Wouldn't chance it with a wheel bearing, unless you are driving to to garage replacing it Laughing
'98 Nile Blue 306 GTi 6
