Latest: cogeim7
Overall: 17185
Online Now [723]:
Visitors: 723
Today: 16470
Total: 147752238
Forums › The Car › 206 Talk › cams.....for gti
cams.....for gti
Forum Index › 206 Talk
charlie-52
PostPosted: Wed Feb 09, 2011 4:23 pm Up
im thinking about getting cams for my 206 gti 138
basicly i want to know what ones i should go for?
i dont want to high lift as its a daily use car and i dont want to have to go through remap, but i want them to have the lumpy sound to them
also what make should i go for for cost effective but not cheap crap
MutilateTheDead
PostPosted: Wed Feb 09, 2011 4:30 pm Up
I was looking at new camsbut everyone on here said to get a re-map too, and i don;t think they come very cheap Sad
206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out!
charlie-52
PostPosted: Wed Feb 09, 2011 4:37 pm Up
i know a lad who had cams in a saxo vts with out a remap and run fine and really sounded amazing Smile
PostPosted: Wed Feb 09, 2011 4:38 pm Up
It's duration you need to be worried about.
Then just fit some Piper Ultimate Road cams to your engine, will need some pockets machining into the pistons. With your standard inlet you'll get all the lumpyness you desire Rolling Eyes
PostPosted: Wed Feb 09, 2011 4:39 pm Up
i don't understand at all.
lumpy idle is cause by the long duration of the camshaft and normally long duration camshaft are quite high lifting and need a remap to work well.
PostPosted: Wed Feb 09, 2011 4:55 pm Up
They also won't give best results on the standard inlet. If you're going to do it, do it properly.
no_offences
PostPosted: Wed Feb 09, 2011 6:12 pm Up
couldnt have said it better, dont do NA tuning unless you do it the best way otherwise your wasting your time and money
Signature removed due to size
no_offences
remaps will make the most of your mods its a dumb idea to avoid it
PostPosted: Thu Feb 10, 2011 2:34 am Up
Also if you want lump cams it means they'll let the engine breath better at higher revs...meaning the rev limit needs to be increased.
charlie-52
PostPosted: Thu Feb 10, 2011 3:08 am Up
okay so basically if you have cams fitted it is without a doubt you will need a remap? or will it still run fine without?
Kersh
PostPosted: Thu Feb 10, 2011 3:56 am Up
im considering some fast road cams with a stainless manifold and a remap to go with my panel filter and cat back.
from what ive heard thats the best thing to do without going down the route of throttle bodies turbo or full rebuilds
Member number: 36
Spanerman
PostPosted: Thu Feb 10, 2011 5:08 am Up
It will run ok, just not to its full potential
Cool
Hello
PostPosted: Thu Feb 10, 2011 5:15 am Up
Give Macj a PM he may be able to help you out here.
PostPosted: Thu Feb 10, 2011 6:57 am Up
Cool
it depends on what profile is the cam.
i know cat. has got some newcamshaft for pug engine which require no remap.
but they are just very mid sport cam only
no_offences
PostPosted: Mon Feb 14, 2011 7:55 pm Up
Seabook wrote:
Cool
to be honest if they dont require a remap there gunna be s**t, , no point modding and tuning if you dont do it right, there's a big difference from my old mapped gti to my standard gt and it had no other performance mods the standard map on a gti 138 is s**te bumpy torque line
