Latest: Stu-mill
Overall: 17131
Online Now [51]:
Visitors: 50
Today: 9850
Total: 104919451
Forums › The Car › 206 Talk › Where's the MAF sensor on a '99 gti?
D4NTP
PostPosted: Thu Feb 10, 2011 12:33 pm Up
Just to confirm, the mass air flow sensor is the little white/grey plastic plug in the bottom of the inlet with the orange resistor in it?
Secondly, where is best/cheapest/quickest place to get one from.
PostPosted: Thu Feb 10, 2011 12:41 pm Up
The MAF is on the air filter
Looks like
Lee180
PostPosted: Thu Feb 10, 2011 12:43 pm Up
Looks like
got it in one Smile
Originate, don't duplicate.
D4NTP
PostPosted: Thu Feb 10, 2011 12:56 pm Up
well mines got an induction kit on it.....no black plastic airflow meter....any ideas?
PostPosted: Thu Feb 10, 2011 12:58 pm Up
Sure you haven't just removed it all together?
D4NTP
PostPosted: Thu Feb 10, 2011 1:00 pm Up
Well i didn't fit it so you've got me wondering....but how the hell would it run right without it....
PostPosted: Thu Feb 10, 2011 1:02 pm Up
Mine ran fine for ages without mine working. Not all cars have them anyway.
D4NTP
PostPosted: Thu Feb 10, 2011 1:07 pm Up
Could do with hereing from anyone with an induction kit fitted, mines appears to be the cheap one off ebay. Comes straight out from the plastic inlet and has an S to the filter behind the fog light. Definately no black plastic air flow meter!
D4NTP
PostPosted: Thu Feb 10, 2011 2:21 pm Up
Lee180 wrote:
Looks like
got it in one Smile
Just to clear this up, the MAF in the picture is not the same as the MAF on the '99 gti, the MAF on this is located in the plastic inlet and is held in by a 8mm set screw. A combinaion of Ebay and Google has pointed this out.
There is no MAF sensor on the GTi. It uses a map sensor and throttle position sensor to calculate load on the engine.
D4NTP
PostPosted: Thu Feb 10, 2011 2:24 pm Up
Well i wish you'd have commented yesterday and saved me a lot of time and effort!
PostPosted: Thu Feb 10, 2011 2:32 pm Up
I got that from the Bosch Part Catalogue for the EW10JP4 engine Laughing
Must be fitted to like the 307 then or something.
D4NTP
PostPosted: Thu Feb 10, 2011 2:36 pm Up
Yeh i looked on google images and saw that pic approximately 1.56million times, and thought....sh@t the tool who had the car before me has done a bodge job and chucked it!
Still having hesitation issues though....
Jayde
PostPosted: Sun Dec 29, 2013 11:48 am Up
Is that true for the 180? Been told by the garage mine needs replacing?
Man the F--- up!
Jake86
PostPosted: Sun Dec 29, 2013 1:00 pm Up
Yeah, that's true for the 180. It has a MAP sensor on the throttle body and needs a different sensor to a normal GTi.
