Latest: airmastertapes
Overall: 17133
Online Now [153]:
Visitors: 152
Today: 14808
Total: 106679044
Forums › The Car › 206 Problems › How to free up the bolt which hold the rear seat belt buckle
PostPosted: Fri Feb 11, 2011 10:55 am Up
That's the one which hold 2 seat belt buckle onto the floor.
Try to take the bolt out, now it got stuck half way through, it won't move at all (can't loosen it or tighten it lol)
any suggestion?
tried to use impact wrench or 1 metric breaker bar with 17mm socket still won't move Sad
MrZiggerz
PostPosted: Fri Feb 11, 2011 10:56 am Up
Impact driver should move it =/
PostPosted: Fri Feb 11, 2011 10:58 am Up
tried. no luck. maybe mine is not powerful enough :\
dan_206
PostPosted: Fri Feb 11, 2011 11:00 am Up
WD40 leave it bit, tighten back up leave bit longer then loosen. Worked with mine. Wink
4th 206 but finally a 180
PostPosted: Fri Feb 11, 2011 11:02 am Up
Yeah some kind of penetrating fluid shoud do it Smile
Cr4zYb0y
PostPosted: Fri Feb 11, 2011 11:04 am Up
Howey wrote:
penetrating fluid
Kinky Laughing
Yeah this worked for me a treat..
1.6 16v XSi Member #21
KILL COUNT: Twisted Evil
Pigeon IIIII
Dove I
Rat/Mouse I
Rabbit I
Hedgehog I
PostPosted: Fri Feb 11, 2011 11:05 am Up
Cr4zYb0y wrote:
Howey wrote:
penetrating fluid
Kinky Laughing
Oh really Andy?? Laughing
Cr4zYb0y
PostPosted: Fri Feb 11, 2011 11:10 am Up
Howey wrote:
Cr4zYb0y wrote:
Howey wrote:
penetrating fluid
Kinky Laughing
It is the weekend Wink Razz
Pigeon IIIII
Dove I
Rat/Mouse I
Rabbit I
Hedgehog I
PostPosted: Fri Feb 11, 2011 11:22 am Up
Almost! Razz
PostPosted: Fri Feb 11, 2011 1:19 pm Up
Most likely covered in rust where the end of the bolt is exposed under the car, penetrating oil should help, dont go mad undoing the bolt, you dont want to snap it.
davieboy86
PostPosted: Fri Feb 11, 2011 1:37 pm Up
I know that bolt, that damn bolt, ended up leaving it half screwed, it didn't poke through the seats at all when put back in.
PostPosted: Fri Feb 11, 2011 5:26 pm Up
i know Sad
have taken the other one out. half of the bolt is covered with rust Sad
will try again tmr
i hate bolts Sad
PostPosted: Sat Feb 12, 2011 5:48 am Up
To be fair Peugeot would most likely reckon that bolt would never be removed during the cars lifetime.
PostPosted: Fri Aug 12, 2011 7:49 am Up
I realise this is old, but I put a short section of scaffolding pole on the end of the socket and it eventually came out!
