Latest: tebas93089
Overall: 17179
Online Now [319]:
Visitors: 318
Today: 12810
Total: 138378776
Forums › The Car › 206 Talk › Fitting Ph2 Washers
Fitting Ph2 Washers
JDave
PostPosted: Fri Feb 11, 2011 11:34 am Up
Hi,
Got myself ph2 washers (actualy waiting on the drivers side to come in) and I am looking to fit.
How is it done?
Its hard to tell because from my bump that ripped it off, there is only a small piece of plastic still connected to the tubing. Pair of pliars to pull it out and shove the new one in?
Just wanted to check before I star tearing things up.
Jordan
Click To View My Project
DeadEyePaul
PostPosted: Fri Feb 11, 2011 11:36 am Up
Just holds on with a clip on the bottom of the jet and connect the tubing to it... Very easy task
PostPosted: Fri Feb 11, 2011 11:38 am Up
You might want to fit a small tie-rap around the end of the tubing where the jet joins it, as it may have stretched and so may leak.
usher
PostPosted: Fri Feb 11, 2011 11:41 am Up
water out of the kettle to soak the old washer piping in if its proving difficult to disconnect from the washer jet
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
JDave
PostPosted: Fri Feb 11, 2011 12:15 pm Up
Got it out. Easy.
Cheers boys.
