Latest: tebas93089
Overall: 17179
Online Now [136]:
Visitors: 134
Bots: 2
Today: 48104
Total: 137819768
Forums › The Car › 206 Problems › drive shsft symptoms
black31
PostPosted: Fri Feb 11, 2011 7:20 am Up
what would be the exact symptoms of u/s drive shafts can any one describe please ?
m
imjeeves
PostPosted: Fri Feb 11, 2011 7:33 am Up
u/s?
vipertsniper
PostPosted: Fri Feb 11, 2011 7:51 am Up
u/s = un-servicable
dont know the symptoms though Smile
am without car Sad
leigh_boy
PostPosted: Fri Feb 11, 2011 9:21 am Up
knocking when going round courners and bumps
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
black31
PostPosted: Fri Feb 11, 2011 1:51 pm Up
so just randomly really would brakeing and acc cause a knocking noise aswell
m
leigh_boy
PostPosted: Fri Feb 11, 2011 2:01 pm Up
you can but that can also be other factors, e.g wheel bearing, discs, ball joints. have to see it \ hear it really. put the wheels on full lock in a car park both ways and see if u get a constant knocking.
*DEAD*206 Gti 138
black31
PostPosted: Fri Feb 11, 2011 2:15 pm Up
does not do it on lock unless i acc hard then does one knock and one when slowing down had new drops, bottom arms and strut top bearings they all needed rep[lacing +but still have this last noise seems as if engine is tilting and then back again sounds like low down o/s to low middle area but difficult to tell really engine mounts dont generally fail
and if they do its usually obvious but they look ok , has anyone ever replaced a good looking mount for a new and fixed similar noises ?
m
leigh_boy
PostPosted: Sat Feb 12, 2011 3:39 am Up
engine or gearbox mount most likeley gearbox, stick hand break on , first gear and pump the clutch like your pulling away but do it quick and try not to stall if it does it then u know its a mount
*DEAD*206 Gti 138
wardie_206
PostPosted: Sat Feb 12, 2011 5:49 am Up
That's wat mine does, I'll get them changed now lol.
black31
PostPosted: Sat Feb 12, 2011 8:16 am Up
this all comfirms what i thought but still no wiser on which one is faulty
m
