Posted: Sat Feb 12, 2011 8:13 am |
just great !!! oil sump is cracked
any one know where i can buy a 206 gti x reg from
easy fix??
so right now
Posted: Sat Feb 12, 2011 8:21 am |
ebay?
| Smoothed & Clean or Nothing at all | |
Posted: Sat Feb 12, 2011 8:22 am |
just looked nothing not much luck
Posted: Sat Feb 12, 2011 8:46 am |
Do a search through the online breakers. I'm sure some will have a knackered engine but with a good sump.
Posted: Sat Feb 12, 2011 8:49 am |
its only a small crack i thing i can sort it with
jb cold weld
crack is only 5mm
Posted: Sat Feb 12, 2011 10:04 am |
lol
don't use those thing on the sump. get it properly weld or get a new one from ebay.
Posted: Sat Feb 12, 2011 10:43 am |
| mistralshining wrote: |
jb cold weld
Brilliant stuff when used correctly
New sump is £231
Posted: Sat Feb 12, 2011 10:46 am |
| MrBSI wrote: |
jb cold weld
New sump is £231  |
really? although i got some at home but i never use it before lol
Posted: Sat Feb 12, 2011 10:48 am |
Posted: Sat Feb 12, 2011 10:51 am |
Ive used JB Weld to repair many different things over the years.
The tricks are:
Key the surfaces & make sure there spotlessly clean.
Mix the JB weld correctly.
Try & press the 2 parts together then use some sort of vice / clamp / support to hold them together.
Let it fully cure.
Id have a go with the JB weld first before replacing the sump.
Posted: Sat Feb 12, 2011 10:59 am |
| MrBSI wrote: |
The tricks are:
Let it fully cure.
Id have a go with the JB weld first before replacing the sump. |
do you have to sand the surface to provide more contact area?
Posted: Sat Feb 12, 2011 11:18 am |
Only problem is if the weld doesn't work it might be too late by the time you find out.
Posted: Sat Feb 12, 2011 11:19 am |
or loctite or belzona. All the same stuff really
| This 206 IS going on a trackday despite it's every effort to stay at home in the garage! | |
Posted: Sat Feb 12, 2011 11:48 am |
I got a spare sump...... how much you want to offer me for it
Posted: Sat Feb 12, 2011 12:26 pm |
| Seabook wrote: |
| MrBSI wrote: |
The tricks are:
Let it fully cure.
do you have to sand the surface to provide more contact area? |
www.specsavers.co.uk/b...pointment/
