Online Now [1024]:
Visitors: 1023
Today: 187542
Total: 148945473
Forums › The Car › 206 Problems › left rear light and third brake light troubles
robdob
PostPosted: Sat Feb 12, 2011 8:10 am Up
when i turn on the side lights only the right rear light comes on... i can indicate left and the light shows, when i press the brake there's no left or third light either... the fuse keeps blowing for the 3rd and left brake too... any ideas?? help needed asap
PostPosted: Sat Feb 12, 2011 8:28 am Up
Have you tried replacing the left brake/tail bulb?
Could be a bad connection or crap on the circuit causing a short. I didn't know the brake lights were on a separate circuit to each other.
MrBombHead
PostPosted: Sat Feb 12, 2011 8:39 am Up
[quote="macca1411"]Have you tried replacing the left brake/tail bulb?
Could be a bad connection or crap on the circuit causing a short. I didn't know the brake lights were on a separate circuit to each other.[/quote]
Left and third are on 1 and right is on another. (Fuse 20 & 21 if I remember right).
The right light is on a 10amp fuse
Left and 3rd are on 15amp fuse
I assume you've tested with a new fuse (15amp) and that keeps blowing?
Possibly bulb issue cutting that out. Hopefully not the 3rd, as its a bi**h to get into that (well is on mine)
Bombhead
My 206 - 206info.co.uk/Forums/v...23351.html
Facebook - www.facebook.com/Bombhead
PostPosted: Sat Feb 12, 2011 9:00 am Up
Thanks for the info. I would have been pulling what little hair I have out if I had a bulb out and a new one didn't work. At least it doubles as a fail safe so you will always have at least one brake light.
PostPosted: Sat Feb 12, 2011 10:40 am Up
Unless the switch is faulty & then you can have none Laughing
MrBombHead
PostPosted: Sat Feb 12, 2011 12:10 pm Up
Which is exactly what happened to me. £4.88 for a switch and fitted it in seconds. All that messing about with bulbs and fuses lol
Bombhead
robdob
PostPosted: Sun Feb 20, 2011 4:32 pm Up
SORTED Very Happy
PostPosted: Sun Feb 20, 2011 4:58 pm Up
robdob wrote:
SORTED Very Happy
What was the fault in the end?
