Latest: sparrowdclxvi
Overall: 17139
Online Now [122]:
Visitors: 121
Today: 14178
Total: 113541853
Forums › The Car › 206 Problems › New battery needed or something else?
Go to page Previous  1, 2
Werdnal
PostPosted: Sat Feb 12, 2011 9:08 am Up
Sure I read somewhere that when alternator is on the way out, they can work in reverse and actually drain current from the battery when the car is parked up. Hence get battery and alternator checked, unless you want to take a chance and get a new battery anyway.
Batteries usually have a code on them. Search online and you can find which of the numbers relate to the battery year code, to see how old yours is.
PostPosted: Sat Feb 12, 2011 9:09 am Up
V9977 wrote:
The disadvantage being that some voltage has to be present in the battery for the alternator to work at all and charge it back up.
So can you run a car that has an alternator without a battery?
PostPosted: Sat Feb 12, 2011 9:11 am Up
V9977 wrote:
What?
You cry over spilt milk, not cake.
PostPosted: Sat Feb 12, 2011 9:14 am Up
Never heard that. I just thought you got both items tested so you replaced the one that wasn't working.
PostPosted: Sat Feb 12, 2011 9:18 am Up
Yes you can. I have known people to change the battery while the engine is running. It saved them having to reset the clock and all the radio stations. Don't know how it would work on a multi-plexed system though.
Werdnal
PostPosted: Sat Feb 12, 2011 9:21 am Up
I agree, but I have known people just assume its a duff battery and bung in a new one, only to get the same problem again. Hence always recommended to get both tested and not just assume batt has gone.
PostPosted: Sat Feb 12, 2011 9:25 am Up
Thats what i thought, V997's statement don't sound right to me.
PostPosted: Sat Feb 12, 2011 9:41 am Up
In theory you only require a battery to start the car, but with winter driving where you have the lights, fan, heated rear screen, wipers, radio as well as the normal running of spark plugs and computers, the alternator cannot produce enough current to cope with it all so therefore the battery provides the extra juice and it cannot be replaced. Over time the battery will go flat but 9 out of 10 times it just needs a good overnight charge and everything is OK again. Cold weather can also drain the power stored in the battery as the electrolyte cannot create the chemical reaction required to produce the current.
MNARAA
PostPosted: Sat Feb 12, 2011 10:23 am Up
E5GDM wrote:
"There\'s no sense crying over every mistake.\r\nYou just keep on trying \'til you run out of cake".
Don't you mean milk?
No, cake. Now go play Portal, because you obviously haven't.
(Or just watch this : www.youtube.com/watch?...hZgszykLs)
There\'s no sense crying over every mistake.\r\nYou just keep on trying \'til you run out of cake.
PostPosted: Sat Feb 12, 2011 10:53 am Up
You're right. If the car is already running the exciter coils are driven by the alternator power itself.
So the battery will be charged in that case. My mistake.
It's V9977 though.. Wink
Page 2 of 2
