Latest: Kifi69
Overall: 17183
Online Now [385]:
Visitors: 384
Today: 84603
Total: 143745065
Forums › The Car › 206 Problems › cracked oil sump
cracked oil sump
00budham00
PostPosted: Sat Feb 12, 2011 8:13 am Up
just great !!! oil sump is cracked
any one know where i can buy a 206 gti x reg from
easy fix??
so Sad right now
robdob
PostPosted: Sat Feb 12, 2011 8:21 am Up
ebay?
00budham00
PostPosted: Sat Feb 12, 2011 8:22 am Up
just looked nothing not much luck
PostPosted: Sat Feb 12, 2011 8:46 am Up
Do a search through the online breakers. I'm sure some will have a knackered engine but with a good sump.
00budham00
PostPosted: Sat Feb 12, 2011 8:49 am Up
its only a small crack i thing i can sort it with
jb cold weld
crack is only 5mm
PostPosted: Sat Feb 12, 2011 10:04 am Up
lol
don't use those thing on the sump. get it properly weld or get a new one from ebay.
PostPosted: Sat Feb 12, 2011 10:43 am Up
mistralshining wrote:
jb cold weld
Brilliant stuff when used correctly Wink
New sump is £231 Shocked
PostPosted: Sat Feb 12, 2011 10:46 am Up
jb cold weld
really? although i got some at home but i never use it before lol
PostPosted: Sat Feb 12, 2011 10:48 am Up
cgi.ebay.co.uk/Peugeot...3cb4a54229
45 quid. Smile
PostPosted: Sat Feb 12, 2011 10:51 am Up
Ive used JB Weld to repair many different things over the years.
The tricks are:
Key the surfaces & make sure there spotlessly clean.
Mix the JB weld correctly.
Try & press the 2 parts together then use some sort of vice / clamp / support to hold them together.
Let it fully cure.
Id have a go with the JB weld first before replacing the sump.
PostPosted: Sat Feb 12, 2011 10:59 am Up
The tricks are:
Let it fully cure.
do you have to sand the surface to provide more contact area?
PostPosted: Sat Feb 12, 2011 11:18 am Up
Only problem is if the weld doesn't work it might be too late by the time you find out.
D4NTP
PostPosted: Sat Feb 12, 2011 11:19 am Up
or loctite or belzona. All the same stuff really
macj
PostPosted: Sat Feb 12, 2011 11:48 am Up
I got a spare sump...... how much you want to offer me for it Very Happy
PostPosted: Sat Feb 12, 2011 12:26 pm Up
Seabook wrote:
The tricks are:
Let it fully cure.
www.specsavers.co.uk/b...pointment/
