Latest: tebas93089
Overall: 17179
Online Now [76]:
Visitors: 75
Today: 33833
Total: 138452420
Forums › The Car › 206 Talk › Auto lights
Auto lights
boozeman
PostPosted: Fri Sep 03, 2010 2:25 pm Up
Can auto lights be retrofitted to my 1999 GT? I already have auto wipers.
GT
PostPosted: Fri Sep 03, 2010 2:29 pm Up
i would of thought it could be done but not very easily
you would need all the parts from a pre-plexed auto light model plus i think the sensor maybe part of the screen??
boozeman
PostPosted: Fri Sep 03, 2010 2:33 pm Up
Anybody know if the sensor is already in the black section on the screen?
GT
PostPosted: Fri Sep 03, 2010 2:44 pm Up
I dont think the sensor is built into the screen, I think it's a separate unit. It was in my renaults anyway.
Geoff
PostPosted: Fri Sep 03, 2010 3:13 pm Up
Yes you can do it! Lee_hdi did it... He bought a kit and just wired it straight into the lighting circuit. Worked quite well from what I remember.
Geoff
PostPosted: Fri Sep 03, 2010 3:17 pm Up
I have found the right profile.... this is the person to speak to: 206info.co.uk/Your_Acc...e=144.html
It might be an idea to email him (details on the link above).
mattievrs
PostPosted: Sat Sep 04, 2010 2:55 am Up
He copied me after i did it to a preplex 206.There are valeo kits on ebay that fit either mux or pre if you search.They are easy to fit too.
NO LONGER ACTIVE ON THE FORUM
charlie-52
PostPosted: Sat Feb 12, 2011 6:31 pm Up
just to answer this old question its a different windscreen altogether the new type censor is the same as the one they use on bmw`s Smile (i work for national windscreens)
PostPosted: Sat Feb 12, 2011 6:38 pm Up
Autolights don't need a different type of windscreen Confused
charlie-52
PostPosted: Sat Feb 12, 2011 6:42 pm Up
oh right well the fittings are certainly different so are the censors
PostPosted: Sat Feb 12, 2011 6:48 pm Up
They can be fitted to normal windscreen as the sensor just measures the light levels
They are just generally fitted to athermal windscreens on the 206, but its not a necessity
charlie-52
PostPosted: Sat Feb 12, 2011 6:53 pm Up
ohh so basically fit the censor a non standard way?
PostPosted: Sat Feb 12, 2011 6:54 pm Up
You can use the same sensor and fit it where it is
