Online Now [112]:
Visitors: 111
Today: 53568
Total: 117007536
Forums › The Car › 206 Problems › Uneven pad wear to the extreme
JJ0063
PostPosted: Sat Feb 12, 2011 6:39 pm Up
Hi all
Been noticing a grinding noise from NSF of the car for a while now gradually getting worse, and today it got loads worse, so lazy me decided to have a quick look & noticed that the OSF pads have got loads of life left, yet the NSF pads look to be pretty much down to the metal.
Why is this? The car drives fine, doesnt pull to the side, brake as hard as you like & the car still stays straight, doesnt seem to be any rubbing (ie. calliper sticking)
im puzzled!
got my MOT in 3 weeks so hopefully if I stick the pads in close to the MOT they wont note me for uneven brake wear.. i hope!
cheers
Antknee
PostPosted: Sat Feb 12, 2011 6:46 pm Up
Maybe they were replaced at different times in the past?
Rob2859
PostPosted: Sat Feb 12, 2011 8:42 pm Up
Specify loads? Every time I change mine there is a fair bit left on one side when the others are to the metal. My mate is a mechanic and he seems to think its just because they are not handed.
PostPosted: Sun Feb 13, 2011 4:44 am Up
Clean / free up both the calipers, copper grease in the right place & make sure you fit Ferodo Premier pads.
You will find the NSF caliper is sticking OR in worse cases the flexi hose needs replacement, check the caliper first Wink
PostPosted: Sun Feb 13, 2011 5:29 am Up
What does 'not handed' mean?
mattievrs
PostPosted: Sun Feb 13, 2011 5:54 am Up
Seized caliper on either the slider bolt or needs the piston and seals refurbing
NO LONGER ACTIVE ON THE FORUM
paulrushton
PostPosted: Sun Feb 13, 2011 6:03 am Up
I'd guess at the sliders being seized. Strip the brake. Clean off an much rust and rubbish as possible. Make sure everything moves. Red rubber grease on the sliders and copper grease on the rest. Rebuild and make sure you pump your break before going for a drive.
Peugeot 206 GTI HDI Black
EdCherry
PostPosted: Sun Feb 13, 2011 7:16 am Up
Wrong greases to use.
Lithium grease on the sliders, and red rubber grease on piston seals.
Copper grease is abrasive do not use it on sliding parts!
PostPosted: Sun Feb 13, 2011 8:08 am Up
I was told last week by friends in the trade they had been warned that copper grease can also attack the rubber seals etc used on brake calipers / cylinders.
paulrushton
PostPosted: Sun Feb 13, 2011 10:07 am Up
The copper grease goes on the back of the pads and where the pads sit in the galilee to prevent them seizing and squeaking.
EdCherry
PostPosted: Sun Feb 13, 2011 10:09 am Up
Yes it does, but then again probably to the same nature that brake fluid itself does.
