Latest: tbafonso
Overall: 17130
Online Now [326]:
Visitors: 325
Today: 57695
Total: 102794657
Forums › The Car › 206 Problems › 206 gti not starting
pugboy495
PostPosted: Sun Feb 13, 2011 8:02 am Up
hi i have a 206 gti on a w reg for a wee project and i saw how helpful this website has been to others so thought i would give it a go. well here goes. i bought a 206 gti which isn't starting there is no spark. the guy i have bought it from says its an immobiliser problem but im not sure. he has put new coil pack on it, new crank sensor, new earth between gearbox new battery. he also told me that has changed the ecu, bsi transponder ring and barrel but it still wont start.! he gave me all the old ecu and stuff that came with the car. it turns over no bother but just wont fire.im just wondering if i should change the ecu and stuff back to the orginal ones and see from there? i did notice that when key is in car ignition but ignition not on and when you ipen door there is no beeps. is that sign of immobiliser problem? any help would be great
206 gti
NICKST
PostPosted: Sun Feb 13, 2011 8:15 am Up
The fuel cut off switch hasn't been activated as it? try reseting it.
giveitsomebar
PostPosted: Sun Feb 13, 2011 8:18 am Up
surely if the fuel cut off has been triggered it would still be sparking ? is the car fueling properly? your p**sing in the wind on here untill you correctly say what its doing?
is it sparking?
is it fueling?
is the fuel pump priming when you turn ignition on?
pugboy495
PostPosted: Sun Feb 13, 2011 8:20 am Up
fuel cut off isn't triggered. there is no spark and i cant hear fuel pump priming but when you turn ignition on there is a clicking noise coming from engine bay
206 gti
NICKST
PostPosted: Sun Feb 13, 2011 8:21 am Up
is it sparking?
is it fueling?
He said it ain't sparking which unless he has tested this could just mean it's turning over but not starting. True tho need more info on what test you have carried out.
Lecktorious
PostPosted: Sun Feb 13, 2011 8:22 am Up
Trade Rating: +59
Have you not started a topic on this already?
'98 Nile Blue 306 GTi 6
pugboy495
PostPosted: Sun Feb 13, 2011 8:23 am Up
yes had started it already but i think i put it in wrong forum so i put it on this one
206 gti
pugboy495
PostPosted: Sun Feb 13, 2011 8:27 am Up
i have checked all fuses, earth cables been replaced, new coil pack, new battery, as i said on post the guy i bought it from had changed ecu transponder ring and bsi. ive got all the old ecu stuff.
206 gti
PostPosted: Sun Feb 13, 2011 8:35 am Up
You coded in the new immobilser?
pugboy495
PostPosted: Sun Feb 13, 2011 8:40 am Up
i dont know it wasn't me who fitted ecu, bsi and transponder. how do you do that? i seen a website that if you send your ecu to them they will make it a free running one and that will do away with immobiliser? will that work?
206 gti
SDK206
PostPosted: Sun Feb 13, 2011 8:57 am Up
Why you want a car that was unimobilised i don't know, especially one that has a gti badge on it!! Smile I personally wouldn't send my ECU to anybody claiming to do this kind of work as god knows what effect it could have on other systems aswell as future reliability.
Just get it to a pug dealer or someone with suitable diagnostic equipment and get the imobiliser programmed, it will save you problems later on i would expect
steve
If in doubt, drop a cog and put your foot down Smile
