Online Now [703]:
Visitors: 702
Today: 127839
Total: 145606839
Forums › The Car › 206 Talk › noise at high revs
noise at high revs
Forum Index › 206 Talk
eddrj
PostPosted: Mon Feb 14, 2011 12:47 pm Up
weird noise at higher revs, fine low revs any ideas ? like a bearing or something mabey
Old car 2000/ 206 2.0 hdi.
eddrj
PostPosted: Mon Feb 14, 2011 2:00 pm Up
still can hear turbo and goes well anyone else had this ??
steevie_b
PostPosted: Mon Feb 14, 2011 2:47 pm Up
I got this too. Like a high pitched whirring? I had timing belt and all pulleys, water pump etc. changed but it's still there. Still not got to the bottom of it.
eddrj
PostPosted: Mon Feb 14, 2011 2:54 pm Up
its hard to explain the noise its ok low revs , so driving low revs now .
High revs makes werid noise think might be a bearing ,dunno wot else it could be ? annoying though.
you got 2.0 hdi aswell thought may be the turbo but still pulls well same as can hear turbo as normal so not sure anyone can help please ????
wull
PostPosted: Mon Feb 14, 2011 3:15 pm Up
this happens on my partners fiat punto.it sounds absolutely normal until you get to 4 thousand rpm and then it goes all high pitched.like you it's hard to explain exactly how it sounds but it doesn't sound too healthy,almost as if something is going to happen.it definately wasn't there before either.
i don't have a clue but my first initial thought was something to do with the camshaft or the engine internally.now i'm not too sure,it still drives ok.
2000 gti
steevie_b
PostPosted: Mon Feb 14, 2011 3:34 pm Up
For me it's noticable at about 1250 RPM...
eddrj
PostPosted: Wed Feb 16, 2011 6:24 am Up
bloody werid mines seems ok now cant hear it.
supercows
PostPosted: Wed Feb 16, 2011 7:45 am Up
i have this too on the gt 138 obviously a non turbo... had the wheels looked at by my mechanic an he says the bearings are fine....
ive got used to it now but wouldnt mind a definate answer if anyone has one.....
supercows
