Online Now [708]:
Visitors: 707
Today: 15329
Total: 146718422
Forums › The Car › 206 Talk › how can you tell when turbo is going ?
Forum Index › 206 Talk
Go to page 1, 2, 3  Next
eddrj
PostPosted: Mon Feb 14, 2011 2:41 pm Up
Apart from loss of power , mine still works and makes werid noise high revs but can hear another bad noise with it ?
Is it safe to drive and wot could it be ?
Im thinking a bearing .
Would it still be going fast if its going ?
It still pulls well though the same.
Old car 2000/ 206 2.0 hdi.
PostPosted: Mon Feb 14, 2011 2:58 pm Up
I checked if mine was running fine via a boost gauge make sure the boost was around what it should be.
You could also Check the pipes both sides to make sure there is no oil leaking out of the seals,
eddrj
PostPosted: Mon Feb 14, 2011 3:01 pm Up
It goes well and can hear it the same so you think its alrit ?
surely going or gone one wouldnt pull same or hear it the same ?
Check the pipes sorry for being stupid i duno where it is lol i dont know about these things
MrrNoName
PostPosted: Mon Feb 14, 2011 3:03 pm Up
sounds like this:
MrrNoName wrote:
hissey noise, like rasping? probs a split pipe.
wine like this:
www.youtube.com/watch?...re=related
bad turbo.
a small bit is ok, not good though Razz
EDIT: also see this one:
and this one:
back to the original poster, dont ignore it if you hear this when looking at the car Razz
eddrj
PostPosted: Mon Feb 14, 2011 3:14 pm Up
yeah sounds most like top first one , but not quite as bad wots that mean
MrrNoName
PostPosted: Mon Feb 14, 2011 3:16 pm Up
need a new turbo mate Sad the fins are rubbing
eddrj
PostPosted: Mon Feb 14, 2011 3:18 pm Up
even though still hear turbo and goes well ?
MrrNoName
PostPosted: Mon Feb 14, 2011 3:19 pm Up
what do you mean still hear the turbo? that is the turbo making the whine lol
eddrj
PostPosted: Mon Feb 14, 2011 3:21 pm Up
ive heard loadsa turbos on youtube that sound hell of alot worse , just saying still works same if i drive low revs cant hear it atall.
Mean how serious is it ?
Getting pi**ed off with this car now and no way can afford new turbo. Crying or Very sad
MrrNoName
PostPosted: Mon Feb 14, 2011 3:24 pm Up
if it was me I would personally keep using it till it get worse, could go on for ages yet potentially?
having said that im not sure of what damage is caused if your turbo falls apart when your doing 70 on the motorway?
im not a turbo expert lol
eddrj
PostPosted: Mon Feb 14, 2011 3:26 pm Up
yeah fu*k it i aint got no choice cant afford new car or turbo, so have to carry on then. Thats wot i was thinking might go on for ages the same. Is it because got it chipped to 115 bhp if i take box off would that help or not you think ?? Too much power ?
Then saying that really high milliage and i have no proof of any new turbo ever and its 2000 w reg.
Thats the other thing though doesnt happen in 5th gear really just high revs or lower gears so going 70 on motorway probably wouldnt notice it much.
MrrNoName
PostPosted: Mon Feb 14, 2011 3:34 pm Up
look on the bright side, at least it doesnt sound like this
www.youtube.com/watch?...ature=fvsr
lol
eddrj
PostPosted: Mon Feb 14, 2011 3:37 pm Up
Do you think would help taking box off or makes no difference ?
probably is just way over due new one probably nothing to do with that chip.
Yeah have seen loads alot worse ones so im thinking it will be ok for ages if i drive low revs its alrit cant hear it atall.
eddrj
PostPosted: Mon Feb 14, 2011 3:41 pm Up
Meant to be driving low revs anyways with this chip
mabey thats all it is lol
eddrj
PostPosted: Mon Feb 14, 2011 3:47 pm Up
just seen one sounds same says sounds like down pipe is blowin wotever that means ?
Page 1 of 3
