Latest: jackrox1992
Overall: 17186
Online Now [688]:
Visitors: 687
Today: 67764
Total: 148601374
Forums › The Car › 206 Talk › tyre question !
tyre question !
Forum Index › 206 Talk
hazzer1501
PostPosted: Mon Feb 14, 2011 6:01 pm Up
got some new tyres for my 17inch tsw alloys , just wondering what tyre pressure they should be at ? Very Happy and just wondering if anyone has seen the ross kemp advert where he goes to mexico , anyone know when its on lol ? Confused
haz!!!!
Mrs_Howey
PostPosted: Mon Feb 14, 2011 6:02 pm Up
I'm pretty sure the new ross kemp program starts on the 21st i want to watch it Very Happy
Sorry i can't help on the tyre pressures though
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
32-34psi
hazzer1501
PostPosted: Mon Feb 14, 2011 6:06 pm Up
thanks mate , looking forward to it Smile
haz!!!!
ersturbo
PostPosted: Mon Feb 14, 2011 6:12 pm Up
should say on the side of the tyres you get mate if it says 32 psi for example only pump it up to about 26-28 psi you need to allow for the temp of the tyres temp gets hot air expands if you pump up to the max pressure youll just at risk of having a blow out lol unlucky but could happen Razz
If you drive fast down back roads etc on the other hand only pump up to about 23 psi
MutilateTheDead
PostPosted: Mon Feb 14, 2011 6:19 pm Up
23 psi? thts wayyyy too low??? Obv depending on what car, run 33 in mine
206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out!
ersturbo
PostPosted: Mon Feb 14, 2011 6:22 pm Up
23 psi is fine providing you warm your tyres up before you go booting it i use to run 24ish psi in my fiesta zetec s as i use to drive on tracks etc with the heat it expands the air which in flats the tyre nicly Wink
PostPosted: Mon Feb 14, 2011 6:23 pm Up
On the side of the tyre it will state the MAXIMUM safe working pressure, in normal running you wont be anywhere near this figure.
Tyre pressures should be set when the tyre is cold / stood overnight.
23 psi is far to low a pressure for a 206, you risk overheating the tyre & causing a blow out not to mention the p**s poor handling & uneven tyre wear it will cause.
33 psi front & rear will be idea.
PostPosted: Mon Feb 14, 2011 6:26 pm Up
23psi cold pressure would skid a lot when raining. i promise
ersturbo
Like I said it's depends on how you drive my bro races a alfa 147 gta cup car abroad he only uses 25psi completely different tyres but he's wet tyres run low to you only need to run that low when driving hard
ersturbo
PostPosted: Mon Feb 14, 2011 6:27 pm Up
Then you pump em up when raining lol
PostPosted: Mon Feb 14, 2011 6:28 pm Up
slick?
ersturbo
PostPosted: Mon Feb 14, 2011 6:30 pm Up
Ye he runs slicks in dry he also runs r888s for 1 of the alfa championships he does
PostPosted: Mon Feb 14, 2011 6:31 pm Up
that make sense. slick don't need much pressure compare to road tyre as their side wall is like concrete.
sillyhilly
PostPosted: Mon Feb 14, 2011 6:45 pm Up
436 PSI
If you dont believe me, search for the answer instead.
Hi Mikey Smile
