Latest: Stu-mill
Overall: 17131
Online Now [68]:
Visitors: 68
Today: 1958
Total: 104889623
Forums › The Car › 206 Talk › cams.....for gti
cams.....for gti
Go to page Previous  1, 2
Antix
PostPosted: Tue Feb 15, 2011 1:38 am Up
Custom - Red Stars
charlie-52 wrote:
i know a lad who had cams in a saxo vts with out a remap and run fine and really sounded amazing Smile
Have a word with Rich [spike_202] - his GTi has cams, done at Pug1off.
Rich is from Telford too Smile
Kersh
PostPosted: Tue Feb 15, 2011 2:28 am Up
*Bridgnorth Wink
Member number: 36
Antix
PostPosted: Tue Feb 15, 2011 4:13 am Up
Custom - Red Stars
*Bridgnorth Wink
Meh - it's close Laughing
"Shropshire" Wink
usher
PostPosted: Wed Feb 16, 2011 8:39 am Up
im getting some standard ones re-profiled as i was told by piper anything over the fast road cams they do will require head work
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Wed Feb 16, 2011 9:24 am Up
With the bigger cams you don't need head work, they need the pistons machining. You also lose the camshaft trigger for the cam position sensor which might throw up a fault code on a standard ECU. But that doesn't matter anyway because you'll need throttle bodies and another ECU anything with other cams.
PostPosted: Wed Feb 16, 2011 9:27 am Up
whether you will need to machine the piston is depends on the lifting of the cam.
you might need stiffer valve spring as well in some case.
but how about the lifters then? as i see most hardcore cam require to use solid lifters, why was that?
PostPosted: Wed Feb 16, 2011 1:17 pm Up
It's the duration that dictates the need to machine pockets into the pistons. The duration tells you how soon the valve opens and how long it stays open. The sooner it opens the closer it gets to the piston - initially the valve moves downwards faster than the piston moves down the bore meaning extra clearance is needed.
Again the longer duration means the opening ramp of the cam opens the valve quicker (in order to reach full lift) meaning a stiffer spring is needed to keep the follower in contact with the cam lobe.
Page 2 of 2
