Online Now [90]:
Visitors: 89
Today: 4522
Total: 106050391
Forums › The Car › 206 Problems › Light issue :/
Light issue :/
Ben.M
PostPosted: Tue Feb 15, 2011 11:45 am Up
Basically when on dipped beam neither the front or rear lights on the right side work, when on full beam both front lights work but the rear right light still doesnt.
The brake and indicator lights work on everything and there is nothing wrong with the left hand side however the rear registration plates do not work at all!
So going by this there is a loose connection somewhere but I dont know where, it did this a while back and it fixed its sefl when my dad played around with the registration lights so im wondering if it may stem from there I just wouldnt have thought that that could affect the whole right side of the car :/
What im asking really is what do you think is wrong and how do I fix it??? :/
Many thanks,
Ben.M
ma.langan
PostPosted: Tue Feb 15, 2011 12:50 pm Up
first check the fuses under the bonnet and under the steering wheel. (all the fuse numbers are in the manual) if the fuses are fine check all ya bulbs, it will most likely be the fuses or bulbs.
Farmer T'aaron!
Ben.M
PostPosted: Tue Feb 15, 2011 1:05 pm Up
Done and done :/
Ben.M
Twidly
PostPosted: Tue Feb 15, 2011 1:27 pm Up
Dodgy connections?
Ben.M
PostPosted: Tue Feb 15, 2011 1:44 pm Up
The connections to the lights themselves seem fine, and I even tried a different set of rear lights but still nothing,
Ben.M
PostPosted: Tue Feb 15, 2011 1:57 pm Up
check the "earth" connection on that side
Ben.M
PostPosted: Tue Feb 15, 2011 2:04 pm Up
Where will that be??? Razz
Ben.M
Ben.M
PostPosted: Wed Feb 16, 2011 1:39 am Up
