Posted: Thu Feb 17, 2011 11:38 am |
Just had my car diagnosed by Pug and they say i need a new driveshaft as the n/s/f regulator ring has cracked. Quoted £300!
Is it not possible to just get a new ring? Only other option is a spare driveshaft from the scrapyard for about £40. Any recommendations?
Posted: Thu Feb 17, 2011 11:48 am |
no ring - i did both at the same time on mine - rings are £10ish on ebay iirc
i still have one i think
Posted: Thu Feb 17, 2011 12:34 pm |
They say regulator ring, is that abs ring, same thing?
Posted: Thu Feb 17, 2011 1:01 pm |
yeah, ABS ring is a regulator ring, if you google them both and click images you'll see they look the same.
Mine had come off completely and i managed to replace just the ring - huge saving
cgi.ebay.co.uk/CITROEN...19c30d4e0c
i got these but check they fit your car first
Posted: Thu Feb 17, 2011 1:04 pm |
just buy the outer cv joint if possible. Had to do this to my wifes cc, what engine is in your car ?
Posted: Thu Feb 17, 2011 1:11 pm |
GTi 2.0 2003.
Baffled as to why Pug would say I need a new drive shaft if it is just the ring cracked.
Quote "after investigation found n/s/f regulator ring on drive shaft cracked"
Posted: Thu Feb 17, 2011 1:14 pm |
erm - maybe because they want the £300???
Changing the CV joint is an option too but what i said originally is the cheapest option.
Posted: Thu Feb 17, 2011 1:22 pm |
Cheers guys, i think i'll go for the abs ring replacement, got it in local garage for MOT Sat. maybe they will pick it up on the checks?
Posted: Thu Feb 17, 2011 5:17 pm |
mdstone wrote: |
Because Peugeot dont list the ring as a spare part, for a main dealer its a complete driveshaft
Posted: Sat Feb 19, 2011 6:23 am |
Can get a new ring for £10 but sizes are 90mm or possibly 86mm. How would I know which would fit?
Posted: Sat Feb 19, 2011 6:37 am |
| Peugeot 206 GTI HDI Black | |
Posted: Sat Feb 19, 2011 8:09 am |
the ebay link i posted was the exact part(s) i used and i have a 2002 GTi
Posted: Sun Feb 20, 2011 9:06 am |
paulrushton - It says those parts are for a 1.6, will it fit a GTi? Bargain for a cv joint.
Edit - CV joint for a GTi is £20, probably worth the extra £10 compared to an ABS ring.
Posted: Sun Feb 20, 2011 9:16 am |
Sorry thought a GTI was a 1.6. My mistake! Whoops!
