Online Now [801]:
Visitors: 800
Today: 213873
Total: 149280751
Forums › The Car › 206 Talk › Does your car make this tune?
Forum Index › 206 Talk
PostPosted: Thu Feb 17, 2011 2:24 pm Up
Hi All,
Well does your car make a tune,not like a warning one(that pug usually have as warning,the peep sound),telling you that you are about to start the car,while the driver door is open,when you turn on the ignition,you hear a tune like the GM models,it's hard to describe the sound of this tune,but i guess you know what i mean,and it goes off when the car is started??so any ideas!!
mine don't have it,but my friend who got the 2007 do Shocked
Tim
Dabamash
PostPosted: Thu Feb 17, 2011 2:27 pm Up
Staff - Daba
The low battery tone? Like a low bong?
kingdom200
PostPosted: Thu Feb 17, 2011 2:28 pm Up
if you where trying to say it makes a sound when u left your door open etc then yer my 180 does it, if thats not what u where trying to say im completely lost lol
PUG1OFF Cat Cams/ ECU project
PostPosted: Thu Feb 17, 2011 2:29 pm Up
Video or sound recording would work wonders
Dabamash
Staff - Daba
yeah, my '55 has a door open tone. The interior light flashes as well.
Jammo
Record it and post it on here?
PostPosted: Thu Feb 17, 2011 2:34 pm Up
Do you mean the "key in ignition" tone? It's to remind you when you get out that you have left the keys in the car.
PostPosted: Thu Feb 17, 2011 2:58 pm Up
That is excatlly the tune I heared a low bong,and I believe you are 100% right,I checked it with PP2000,and in the Engine ECU while doing Global test,it showed a fault of low battery voltage,and he said that it's true after I told him so,so mystery is solved :D,thanx.
@Guys-Well I know the tune that comes on when you forget to turn off your headlights,and it's the same tune if you leave the key in the ignition,and it does it in my car because I got automatic gearbox,if I leave it on Drive postion.
Thank you all for your help,and I will post a Vid if he didn't changed the battery already..lol
Dabamash
PostPosted: Thu Feb 17, 2011 2:59 pm Up
Staff - Daba
I win ladies Wink
Jay794
PostPosted: Thu Feb 17, 2011 3:07 pm Up
Mine beeps when the key is in the ignition and the door is open, if I drive with a door open the interior light flashes too. 02 plate 2.0HDi Multiplexed DTurbo spec
PostPosted: Thu Feb 17, 2011 3:38 pm Up
Dabamash wrote:
I win ladies Wink
Thumbs Up
bertt
PostPosted: Thu Feb 17, 2011 4:16 pm Up
mine makes an annoying noise,between 4000-4500 revs when the exhaust blows the cobwebs out your ears, im not treated to the electronic bleeps with a y-reg unfortunately
