Online Now [567]:
Visitors: 566
Today: 19839
Total: 146918408
Forums › The Car › 206 Problems › Getting Super Glue off
Southall
PostPosted: Thu Feb 17, 2011 4:15 pm Up
I realise it was incredibly stupid DOH!!! to get some on there anyway but I needed a quick fix.
Unfortunately I have idiotically Evil or Very Mad dripped some onto my paintwork and I'm not sure how to remove it without screwing the paintwork, or if that's even possible.
I've heard that brake cleaner can help I'm not sure how accurate that is and all the super glue "removers" will damage the paintwork, I would've thought?
ANY help appreciated Smile
Project: coming soon
OH MY. slam.poke.drop.tuck.dope
Wiliam_morgan
PostPosted: Thu Feb 17, 2011 4:22 pm Up
always try belt sander! but might take some paint off too, i wouldt like to try brake clear maybe dry autoglym Intense tar remover tho :S or some clay bars if u understand the princibles of "claying"?
someone will confirm if claying will remove it or not im sure Smile
Southall
PostPosted: Thu Feb 17, 2011 4:29 pm Up
Yeah thought about claying but not sure that'd be strong enough? its a hefty dribble Laughing
Might just end up re-spraying Sad
Antknee
PostPosted: Thu Feb 17, 2011 4:51 pm Up
Its risky but maybe very fine wet and dry paper? Maybe use a very small bit wrapped around the blunt end of a pencil, being veryy careful taking it down to the laquer
Mrs_Howey
PostPosted: Thu Feb 17, 2011 4:56 pm Up
Can you not get some one with long nails to try and pick it off, or try a butter knife and be very careful, try lifting it off the surface.
Sticky stuff remover might work, not sure tho
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
Southall
PostPosted: Thu Feb 17, 2011 5:02 pm Up
Done that... Might try the sand paper, it's only...sniff... paint after all Laughing
Oh well I'll give the sticky stuff remover a go, then it's on with the sand paper!
Jamie1337
PostPosted: Thu Feb 17, 2011 5:04 pm Up
Trade Rating: +37
I work with glue for a living dont try sanding it down it'll be slow and you'll cause damage to surrounding area in the process, you need to get some solvent which will get rid of the glue far easier. If I were you I'd test it on an inconspicous area before attempting the surface mind to make sure you dont do any more damage than good (i.e. underneath bonnet). If it was me I'd then T cut the surrounding area then polish + wax to reprotect the paintwork.
Light Right Foot FTW!
PostPosted: Thu Feb 17, 2011 5:19 pm Up
nail polish remover, diluted it with water and do it quick!
otherwise it will damage your paintwork
Southall
PostPosted: Thu Feb 17, 2011 6:25 pm Up
Solvents it is then, I'll blame you guys if I have a GIANT patch in my paintwork!
Laughing I joke
PostPosted: Thu Feb 17, 2011 6:31 pm Up
Tried heating it up with a hairdryer and pealing it off? or diesel?
Southall
PostPosted: Thu Feb 17, 2011 6:36 pm Up
Haven't tried diesel yet...
PostPosted: Thu Feb 17, 2011 6:39 pm Up
Infact have you tried tar and/or glue remover?
Southall
PostPosted: Thu Feb 17, 2011 6:41 pm Up
Yep I've tried that already, didn't budge one bit!
bellevuespares
I seen this post and thought of petrol!
Lee maybe right in saying diesel but i know for sure petrol will do the trick without damage.
ive tryed and tested petrol to remove bitumen from a WHITE car, Insurance wrote it off as CAT C but it cost me ONLY £5 petrol to remove it all.....
Buffed it afterwards and was BRILLIANT WHITE AGAIN! Cool
Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes!
-Dave-
PostPosted: Thu Feb 17, 2011 6:42 pm Up
Trade Rating: +36
Maybe someone will know better but maybe trying chewing gum remover might do the trick, The type that freeze's it before you take it off. I used it to get the glue off when I debadged my car but I sprayed it onto a cloth not the car, Worked a treat. Washed the car right afterwards so noon was left on the paintwork.
Ex 206 Owner.
