Latest: ArtistKS
Overall: 17145
Online Now [108]:
Visitors: 107
Today: 18561
Total: 116075461
Forums › The Car › 206 Problems › bleeding the cooling system
Rusky
PostPosted: Thu Feb 17, 2011 12:37 pm Up
im trying/want to bleed the cooling system as i think there could be an air lock on the rad to the left of top hose there seems to be a bleed valve but iv read the bleed valve is to the right and behind the dipstick also is it a pressured system and whats the best way to do it please
im liking this little toy
PostPosted: Thu Feb 17, 2011 1:20 pm Up
On the GTi there is a bleed screw on the thermostat housing and the heater hose. I'm sure other models will be a similar set up.
Any air on the radiator will find its way into the small hose that leads to the reservoir.
PostPosted: Thu Feb 17, 2011 1:45 pm Up
While car is cold,and engine is not running,open the valve on the heater hose,it's the one on the left while you are standing in front of the car,open it,and also open your cooler reservoir,and while you add coolant+destiled water to the reservoir,you will see the water coming out from the valve taking all the air out,and it means that you coolant system is full now :D,so close the valve,and then close the reservior cap after you reach the right level (Max.)
Rusky
PostPosted: Thu Feb 17, 2011 9:14 pm Up
cheers guys i'll try it today Edward do u bleed while old also is there a bleed valve for the heater matrix
