Online Now [73]:
Visitors: 72
Today: 19951
Total: 143088440
Forums › The Car › 206 Talk › PPT30
PPT30
returnofjim
PostPosted: Fri Feb 18, 2011 6:19 am Up
Does it need to be connected to an original radio for the time etc to display?
James
Hello!
PostPosted: Fri Feb 18, 2011 6:24 am Up
No, if you fit an aftermarket stereo then the cd and radio display will say "out" instead of the current track etc but it will displayed on the hu instead.
returnofjim
PostPosted: Fri Feb 18, 2011 6:30 am Up
this one must be dead then, it illuminates but nothing on the display.
Hello!
PostPosted: Fri Feb 18, 2011 7:02 am Up
I did a fix for it, check the howto guide. Or you could cover postage to me and back and for a fiver ill do it if you dont have a soldering iron etc
PostPosted: Fri Feb 18, 2011 7:03 am Up
I did what dj said, although when mine was broken it wasn't illuminating at all.
returnofjim
PostPosted: Fri Feb 18, 2011 7:14 am Up
I did your fix on it but still nothing on the display, the bulbs illuminate fine, saying that though ive only tested it by wiring it to a battery.
Hello!
PostPosted: Fri Feb 18, 2011 7:33 am Up
The display needs to be connected to the car for it to actually display anything Wink
PostPosted: Sat Feb 26, 2011 1:27 pm Up
how did you test the ppt30 using a battery?
