Online Now [226]:
Visitors: 225
Today: 82151
Total: 142987853
Forums › The Car › 206 Talk › Manual headight adjustment
Urban
PostPosted: Fri Feb 18, 2011 10:48 am Up
Fitted some standard crystal headlights back on my 180 (did have twin angels fitted by previous owner) but don't have the headlight adjuster motors yet so my lights are pointing straight at the ground and not really lighting up the road ahead.
I don't have a Haynes manual, so is it possible to adjust the dipped beam so I can actually see the road at night?
Also if I could manually adjust them, would I need to adjust them back again when I got the adjuster motors or wouldn't it matter?
Thank you in advance!
Mike
Was China Blue Gti, now Black Gti 180
PostPosted: Fri Feb 18, 2011 10:50 am Up
I think I might be right in saying that without having the adjuster in, the block piece in the light will just move around when you go over bumps and stuff so no matter if you align it with the car still it can still move because there is nothing to stop it (which the adjuster does).
PostPosted: Fri Feb 18, 2011 10:51 am Up
Yeah you need an adjuster in, either a manual one or a electric one, as the ball and socket holds the lamp at the right angle
Urban
PostPosted: Fri Feb 18, 2011 10:57 am Up
Bugger! Lol. Cheers for the quick response Smile
DMB2101
PostPosted: Mon May 23, 2011 6:21 am Up
How do you remove the adjuster from the headlight as i am scared i will snap the ball joint and would have to buy another leveller?
2003 1.4 hdI
PostPosted: Mon May 23, 2011 6:41 am Up
Twist and pull, the arm is pretty fragile though.
