Online Now [86]:
Visitors: 85
Today: 38898
Total: 138558347
Forums › The Car › 206 Problems › MOT History - Suspension
myke
PostPosted: Sat Feb 19, 2011 9:36 am Up
Hiya,
Just looked at the history of my car's MOT, because I'm intrigued to know about the previous MOT, I don't think it should've passed but I bought it from a garage and it was the garage that had passed it... fishy huh? When I bought it, the middle seatbelt in the back didn't work and the windscreen washers had been cut. (Didn't notice this until I got home!)
So I fixed them problems, just checked the advisory of last time and it says this:
Advisory Notice issued
Both Front suspension has slight movement at a wishbone pin or bush
The MOT is in May.
Will this be an expensive thing to fix if it fails it?
taaa.
PostPosted: Sat Feb 19, 2011 9:41 am Up
Just bascily wishbone bushes I think that means.
Not bad to do, I just buy new full wishbones easier Job and not expensive.
PostPosted: Sat Feb 19, 2011 9:43 am Up
sounds like the lower arm bushes will need a pair of new lower suspension arms
talking bout £200ish for a cheap pair fitted i reckon bearing in mind the faxt the tracking will have to be reset after. genuine ones will be nearly double that i reckon.
wishbone is not cheap, however the bush on the wisbone is quite cheap.
myke
PostPosted: Sat Feb 19, 2011 9:50 am Up
blah. I hope it is cheap lol, because I really can't afford anything expensive on it at the mo... finding a job around here is like trying to find cheese on mars. Cheers for the help guys.
I have a funny feeling, looking at the history that the MOT station that MOT'd my car last time passed it when it should've failed.. when I got it, I found out in the first two weeks that: the middle rear seatbelt did not work and somebody had cut the windscreen wash tubing, meaning none of it worked. It should've failed, so now I'm really worried that there's something even bigger underlying that he didn't say about.
MrZiggerz
PostPosted: Sat Feb 19, 2011 10:15 am Up
Can we have the Garage name so we know to steer clear Wink Thanks.
Get it serviced, they will tell you if anything is seriously wrong.
Ash
PostPosted: Sat Feb 19, 2011 10:19 am Up
£30 I got mine for.
myke
PostPosted: Sat Feb 19, 2011 10:24 am Up
Cheers Ash & Ziggerz, next time I log onto the history I'll post it here Very Happy
M60SHW
PostPosted: Sat Feb 19, 2011 10:55 am Up
Did you not inform vosa/ relevant authority about the garage as that is a bad offence and they should loose there licence for that, and if you get a Haynes manual and the wishbones (about £35 each) and probably track rod ends aswell (about £10 each) and do it you self it's easy enuf.
Team, ST
Team, Gti 138 track slag
Jammo
PostPosted: Sat Feb 19, 2011 6:47 pm Up
it was only an advise they might not of got any worse than last year they are wear and tear items dont buy the any parts until it has failed ?
myke
PostPosted: Sat Feb 19, 2011 7:55 pm Up
Didn't know I could inform them lol, and awesome Very Happy
Got one out of three
& I'm not getting the parts until it fails Jammo Razz
thanks for all the help guys! Very Happy
