Latest: S2cgm
Overall: 17178
Online Now [446]:
Visitors: 445
Today: 62349
Total: 137413384
Forums › The Car › 206 Problems › Vibration when I pull away
LiamGTi180
PostPosted: Sat Feb 19, 2011 12:05 pm Up
I have a 206 gti180 and when I pull away the whole car vibrates. The slower I pull away the more it does it. The clutch does not slip but it sounds like it is going to stall. Very awkward to drive in traffic. Any ideas? Or is this common with these cars? Thanks
PostPosted: Sat Feb 19, 2011 12:12 pm Up
Common clutch shake just add a bit more revs and you will be fine.
paulrushton
PostPosted: Sat Feb 19, 2011 12:29 pm Up
DMF?
Peugeot 206 GTI HDI Black
dturbopeck
PostPosted: Sat Feb 19, 2011 1:38 pm Up
had same fault with mine, got really bad. New clutch kit and flywheel skim needed
brimbo
PostPosted: Sat Feb 19, 2011 3:10 pm Up
ive got the same problem, but only when i use the clutch, any possibility its a loose nut or something under the bonnet?
W-reg 1.4 LX
dturbopeck
PostPosted: Sat Feb 19, 2011 3:23 pm Up
nah its a clutch fault, every 180 has this fault at some stage.
brimbo
PostPosted: Sat Feb 19, 2011 5:24 pm Up
ive just got a regular 1.4 model Sad
W-reg 1.4 LX
dturbopeck
PostPosted: Sat Feb 19, 2011 5:39 pm Up
more than likely be the clutch, hard to say with out driving it.
