Latest: Beduff1977
Overall: 17134
Online Now [588]:
Visitors: 587
Today: 173578
Total: 108108642
Forums › The Car › 206 Problems › Urgent electrical fault
PostPosted: Mon Feb 21, 2011 2:51 pm Up
On tonights menu:
Fried BSI unit Laughing
gavlar83
PostPosted: Mon Feb 21, 2011 3:21 pm Up
i have followed the procedure on rebooting the bsi and nothings changed,someone mentioned finding a wire?is that a possiblity?
is learning slowly but surely Smile
Signature Removed - Please See Your PM's
PostPosted: Mon Feb 21, 2011 3:28 pm Up
PostPosted: Mon Feb 21, 2011 3:30 pm Up
If your 100% sure the fuses are ok & the BSI has been rebooted correctly then either:
Send BBA the BSI unit for test & repair
www.bba-reman.com/uk/index.aspx
OR
Get it towed to the Peugeot main dealer / someone with Peugeot Planet diagnostic kit.
Multiplexing bites if you dont know what your messing around with Wink
PostPosted: Mon Feb 21, 2011 3:42 pm Up
I'll bet a million pounds its a blown fuse. Did you take them out and check each fuse, or just look by eye? Do you know which is the Stereo fuse?
I would have thought Lee and Mr.BSI would have told you which one it was!
PostPosted: Mon Feb 21, 2011 3:49 pm Up
Fuse list is:
On the forum.
On the Peugeot website in the online owners manuals.
In the owner's handbook that comes with the car.
How much more hand holding do people want Wink Rolling Eyes
gavlar83
PostPosted: Mon Feb 21, 2011 3:51 pm Up
i took the fuses out 1 by 1 an checked em correctly,looks like im gonna av to dip into my back pocket Sad
PostPosted: Mon Feb 21, 2011 3:53 pm Up
Not only that, but if he's short circuited the electric system, it could have blown any fuse as the power surge could have gone anywhere. Was his own daft fault for not disconnecting the battery.
PostPosted: Mon Feb 21, 2011 3:54 pm Up
You did have the BSI shut down correctly & battery disconnected BEFORE you pulled any fuses?
You wouldnt pull plugs out from inside your computer while its powered up, a multiplexed 206 is no different.
Its a software driven digital CAN VAN electrical system controlled by the BSI unit ( Built in Systems Interface which is the main brain )
PostPosted: Mon Feb 21, 2011 3:57 pm Up
Or in layman's terms, you wouldn't have open heart surgery wide awake, you'd be knocked out Wink
gavlar83
PostPosted: Mon Feb 21, 2011 3:58 pm Up
im new to peugeot and have only had it 3 days,i didnt realise they were this technical,i think iv messed it up by trying to do it myself,im just gnna have to get sumone whoknows what they r doing to have a proper look,thanks for helping anyway.and lee iv made a mistake hasnt everyone?so lay off with the attitude!!
PostPosted: Mon Feb 21, 2011 3:59 pm Up
Electrics is electrics. You should always disconnect the power, its common sense.
PostPosted: Mon Feb 21, 2011 4:01 pm Up
just like you won't change a light bulb when the circuit is live Laughing
PostPosted: Mon Feb 21, 2011 4:03 pm Up
Exactly what wires have been touched?
Did you test the fuses with a test meter or did you just look at them?
gavlar83
PostPosted: Mon Feb 21, 2011 4:13 pm Up
i jus looked at them,i touched the red and green and yellow together,the rac is looking it over now so hopefully he will find the fault,and nothingt costly hopefully
Page 2 of 4
